headlight wiring question #244988
03/06/09 03:01 PM
03/06/09 03:01 PM
Y-town ohio
68valiant68 Offline OP
Y-town ohio
wanna be able to use the headlights on my drag car, but i need to know how to wire for low beams and the ground?
Re: headlight wiring question [Re: 68valiant68] #244989
03/06/09 04:40 PM
03/06/09 04:40 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
If you are wiring it to an aftermarket switch
1. run a wire from hot to a fused switch
2. run a wire from switch to a ground
3. run wire (hot) from switch to headlights
4. if using the stock pig tail on the headlights,figure out low beam by hooking up 12 volts to the wires and adbandon the other wire.
5.each light grounded at the radiator support.
Re: headlight wiring question [Re: 68valiant68] #244990
03/06/09 05:18 PM
03/06/09 05:18 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
I would recommend that a relay should be used..
Just my $0.02..
Re: headlight wiring question [Re: Sinitro] #244991
03/06/09 05:53 PM
03/06/09 05:53 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Just my $0.02..
Re: headlight wiring question [Re: Sinitro] #244992
03/06/09 05:56 PM
03/06/09 05:56 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Just my $0.02..
Your right Let me change that to if you are using a aftermarket switch other than ( ARC) use a relay.I forgot as I dont use relays.
Re: headlight wiring question [Re: cudabunch] #244993
03/06/09 10:53 PM
03/06/09 10:53 PM
Y-town ohio
Y-town ohio
I'm running the arc overhead panel
Re: headlight wiring question [Re: 68valiant68] #244994
03/06/09 11:49 PM
03/06/09 11:49 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Then you are good to go
