Re: Engine run test stands [Re: Uncle Barry] #2449306
02/09/18 11:03 PM
02/09/18 11:03 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
I made brackets that sit on the legs of a engine hoist (cherry picker). Space is a premium in my garage, and I didn't want to have to store something else that took up a lot of room and was hard to move around. The 2 brackets I made take up very little space, and are not heavy at all. All the steel was scrap I had laying around, so it cost me nothing except a little time to make it. I also made a switch panel and wiring with a spare Chrysler electronic ignition box I had that attaches to the hoist with 2 bolts when I use it as a "run stand". Same with oil pressure and temperature gauges. I have used this several times and it works great and it's very easy to set up. Works with both small blocks and big blocks.
Re: Engine run test stands [Re: mrrandyj] #2449310
02/09/18 11:16 PM
02/09/18 11:16 PM
^^^ Trick! I like that.
Re: Engine run test stands [Re: Uncle Barry] #2449312
02/09/18 11:18 PM
02/09/18 11:18 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
You can cut down a torque convertor to use the ringgear only.
I wouldn't use a complete torqueconvertor for balancing reasons. The insides won't be held centered because there's no transmission input shaft.
I mounted a neutral flywheel against the B&M balanced flexplate and used slightly longer bolts into the crank flange.
I build mine from a spare cart and some scrap metal.
Here it is with a 360ci Small Block installed;
Re: Engine run test stands [Re: pittsburghracer] #2449462
02/10/18 12:28 PM
02/10/18 12:28 PM
Big Western Pencilveinya
U
Uncle Barry Offline OP
U
Originally Posted By pittsburghracer
Originally Posted By Uncle Barry
Has anyone ever bought one of these from the Walmart site? https://www.walmart.com/ip/Mobile-Engine-Testing-Station
Barry I bought some plans and started building my own because I didn't want to buy a cheap piece of crap and bandaid it to make it stronger. Mine is about 80% finished, bought gauges, and I bought a fixture off a Moparts member to mount a starter on a big block. I think I have it sold as I have been trying to clean-up some but if the deal falls through I can let you know if you are interested. It is made to fold up so you can lean it against the wall if you want to.
New engine breakin bench 003 by John Cadamore, on Flickr
engine stand 001 by John Cadamore, on Flickr
engine stand 002 by John Cadamore, on Flickr
let me know John. Terry and I are looking for something like this.
Re: Engine run test stands [Re: Uncle Barry] #2449466
02/10/18 12:31 PM
02/10/18 12:31 PM
U
U
You folks are really creative and have great fabrication skills that's for sure!
Re: Engine run test stands [Re: mrrandyj] #2449551
02/10/18 03:24 PM
02/10/18 03:24 PM
E
earlymopar Offline
earlymopar  Offline
E
If you were so inclined, I'd suggest you have a sellable product with that.
- EM
Re: Engine run test stands [Re: Uncle Barry] #2449614
02/10/18 05:12 PM
02/10/18 05:12 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The cherry picker mounted one is very clever, good work.
68 Barracuda Formula S 340
Re: Engine run test stands [Re: Bad340fish] #2450431
02/12/18 12:29 AM
02/12/18 12:29 AM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Re: Engine run test stands [Re: Uncle Barry] #2450623
02/12/18 12:57 PM
02/12/18 12:57 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Yall would laugh if you saw mine, lol. When I said we built it out of scrap, that's exactly what it is...pieces from an old combine, etc. lol
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Engine run test stands [Re: mrrandyj] #2450629
02/12/18 01:04 PM
02/12/18 01:04 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
Now that's a great idea ... I already have the folding engine crane ... just need to make some mounting brackets!
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Engine run test stands [Re: an8sec70cuda] #2450632
02/12/18 01:13 PM
02/12/18 01:13 PM
Lets have a look, pics please! On a side note someone mentioned loading the eng, I'm wondering if you build one with a functioning 727 behind it is there a way to load the eng to help with ring seating? here is a good read on this: go to www.mototuneusa.com then scroll down & click on "breakin secrets". their take is that you get ONE shot to get an excellent ring sealthat will give good leakdown numbers as opposed to a "good" or "so so" ring seal & the gist of it is to load the eng repeatedly by goosing the throttle during the breakin. Andy I like your that stand is more open in the back cuz I need more access to that area & my next one will be able to be rotated for sure.
Re: Engine run test stands [Re: OUTLAWSSAA] #2450634
02/12/18 01:14 PM
02/12/18 01:14 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
OUTLAWSSAA,
Are you just using the transmission as a bellhousing with a flywheel or do you have a pump and a converter in there?
Thanks,
Bill
Re: Engine run test stands [Re: ScottSmith_Harms] #2450916
02/12/18 10:12 PM
02/12/18 10:12 PM
templeton,ma
coro500net Offline
coro500net  Offline
templeton,ma
Been using that Walmart test stand for a few years,works fine. Had to do some minor mods to the stand for the block motor mount hook up.
Re: Engine run test stands [Re: Uncle Barry] #2450920
02/12/18 10:20 PM
02/12/18 10:20 PM
P
Porter67 Offline
Porter67  Offline
P
I need to take a pick of my fugly deal, I bent the ramps I load my bobcat with so I cut one in half and each part got a motor mount and a rad across the front.
I cut the other ramp in half, drilled holes for the trans tail mount and thats that.
Like a fat chick or a honda 50.
Re: Engine run test stands [Re: Uncle Barry] #2450974
02/12/18 11:10 PM
02/12/18 11:10 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Best of all time right here!
Re: Engine run test stands [Re: Uncle Barry] #2451098
02/13/18 09:28 AM
02/13/18 09:28 AM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
