Re: Starter cable gage needed
[Re: mopar dave]
#2448116
02/07/18 05:57 PM
02/07/18 05:57 PM
Posts: 11,737 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I've checked them with an ohm meter and caught bad ones. But it's a big difference when trying to run a few hundred amps through it. I usually just change them out occasionally or if an issue pops up. I would think a voltage drop test from the battery positive to the output stud of the main switch, while the starter is engaged, would show any issue with the switch.
[Re: mopar dave]
#2448449
02/08/18 12:42 PM
02/08/18 12:42 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Dont know, but i can check. Maybe 10yrs old longacer switch. What should all the measures be to get a passing grade? Dave take a few mins to go to youtube and look up "voltage drop test". once you understand how to test, your electrical problems will go away and any that come up can be solved quickly. this is a skillset that every DIY'er should know how to use. also the correct answer is "0" voltage loss across the switch. climbing down off of soap box Joe
Without Data, you’re just another guy with an opinion.
[Re: mopar dave]
#2448559
02/08/18 03:52 PM
02/08/18 03:52 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Correct, any resistance across a switch, replace it.
Was looking at a Ron Francis catalog this morning for something and ran across his trunk mount battery cable kit for street rods with EFI, power accessories, etc. 1ga.
[Re: mopar dave]
#2448564
02/08/18 04:04 PM
02/08/18 04:04 PM
Posts: 43,311 Bend,OR USA
Cab_Burge
I would , and do , use either #1 or #0 for my trunk mounted batteries depending on the compression and if it is a street car or race only car. #0 on race only cars with multiple grounds also ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: dvw]
#2448600
02/08/18 05:13 PM
02/08/18 05:13 PM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
Most tech guys track test is to flip the switch to off and have you try and crank. Better make sure it shuts the starter solinoid feed circuit off if the starter main feed doesn't go through the switch. Doug It will.
[Re: mopar dave]
#2448615
02/08/18 05:45 PM
02/08/18 05:45 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Rule book says master switch must shut off all electrical functions. Ever have a starter "stick", solenoid jam and keep the starter engaged? I have. How you going to fix that when the starter is hooked directly to the battery? If running the starter smokes your master switch, you need a better master switch.
[Re: mopar dave]
#2448866
02/09/18 01:04 AM
02/09/18 01:04 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I used aircraft wire, it has like 120 strands in it in a 1/0 size, and it can handle the amperage of a standard wire that is 1 size larger. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
