Making progress on TKO install
#2444994
02/02/18 01:22 AM
02/02/18 01:22 AM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
Purchased a conversion kit from SST to take my ‘72 Charger from A/T to five speed M/T. It’s slow at two or three hours at a time here and there but the pedals and clutch master cylinder are in. Steering column is been converted. Time to confirm some measurements for the clutch disc clearance then it should be time to cut the tunnel. By far the biggest upgrade for me to date.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Making progress on TKO install
[Re: GoodysGotaCuda]
#2445415
02/02/18 11:27 PM
02/02/18 11:27 PM
dfsmopars
Kentucky
You likely received another bracket to go from the master cyl mounting bolt down to the frame to keep the firewall deflecting. My kit from sst included that. You’re right. Probably needs to be the next step. BTW is there supposed to be a rubber seal or something for the side of the bellhousing? There’s like a 3x3 hole where linkage or hose feeds through. Getting ready to take the finger/bearing clearance measurements and just thought about it.
[Re: dfsmopars]
#2445426
02/02/18 11:57 PM
02/02/18 11:57 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
You likely received another bracket to go from the master cyl mounting bolt down to the frame to keep the firewall deflecting. My kit from sst included that. You’re right. Probably needs to be the next step. BTW is there supposed to be a rubber seal or something for the side of the bellhousing? There’s like a 3x3 hole where linkage or hose feeds through. Getting ready to take the finger/bearing clearance measurements and just thought about it. My kit came with a giant rectangular grommet I didn't use on my T56. It may be a TKO grommet.
[Re: dfsmopars]
#2446106
02/04/18 11:15 AM
02/04/18 11:15 AM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
Wow that master cylinder setup is a lot nicer than the American Powertrain ones I've seen. Doing a T56 Magnum swap on my Duster this year as well.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: goldduster318]
#2446199
02/04/18 02:00 PM
02/04/18 02:00 PM
dfsmopars
Kentucky
It’s a Wilwood cylinder. This is my first experience with an install like this so nothing to compare it too but I am pleased with this part of the set up so far. Reservoir is in and the brace to prevent the firewall flex.
[Re: dfsmopars]
#2450221
02/11/18 07:12 PM
02/11/18 07:12 PM
dfsmopars
Kentucky
I don’t know if anyone else can see the pictures but all I see are file names.
[Re: dfsmopars]
#2450296
02/11/18 09:31 PM
02/11/18 09:31 PM
dfsmopars
Kentucky
The kit SST sent to me had a Quick Time bell housing. I did not have any issues with aligning it.
[Re: dfsmopars]
#2454435
02/20/18 08:49 AM
02/20/18 08:49 AM
dfsmopars
Kentucky
Tunnel is tacked in. Patch is prepared.
[Re: dfsmopars]
#2455966
02/23/18 02:14 AM
02/23/18 02:14 AM
Posts: 730 Nampa, ID
MadMatt
Nampa, ID
Here's a link to a video I made of a TKO-600 install in my 70 Dart. The BEST mod I ever did! It was super tight on an A-body, but so glad I did it. https://www.youtube.com/watch?v=5n67-K41YkA
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
[Re: MadMatt]
#2456039
02/23/18 10:56 AM
02/23/18 10:56 AM
dfsmopars
Kentucky
Big difference in the a body clearance and this third gen b body for sure.
[Re: goldduster318]
#2458718
02/28/18 03:56 AM
02/28/18 03:56 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Wow that master cylinder setup is a lot nicer than the American Powertrain ones I've seen. Doing a T56 Magnum swap on my Duster this year as well. That's the Keisler/Wilwood design that SST has carried over in it's line up, I've converted my TKO equipped vehicles over to that master set up, as well as a few customers vehicles, proven very reliable with ZERO issues, and many years/miles of use...
[Re: dfsmopars]
#2460111
03/02/18 08:30 PM
03/02/18 08:30 PM
dfsmopars
Kentucky
Tunnel is completely in with Dynaliner. Trans is in with oil. Drive shaft is ordered. Gotta wire in neutral and reverse switches, bleed matster cylinder, install steering column and carpet and done.
