Page 2 of 3 1 2 3
Re: Soft Lok Clutch on the street [Re: Jeremiah] #2444030
01/31/18 01:36 PM
01/31/18 01:36 PM
Washington
madscientist Offline
Washington
Originally Posted By Jeremiah
I just received one of the two bells I sent to Hyatt. It's really, really nice and Chris is great to work with.
Not only did he add the window, the surfaced it to square it up. I was really impressed with that.
What did it cost and how long did it take? I had to wait almost 2 months for Lakewood and that was 2 years ago.
I have a second bell housing I need windowed. I have no problem using Hyatt.
Re: Soft Lok Clutch on the street [Re: lockjaw-express] #2444293
01/31/18 10:33 PM
01/31/18 10:33 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
I try to remain silent and out of the BS on most group chats but adj clutches on the street are close to me heart and I cant understand some of the stuff I hear......
Guys claim that you cant chassis dyno a slipper clutch... incorrect. You are in high gear for a longer period of time on the track then any dyno pull.... so if it slips on the dyno, I guarantee it is going to drive through the clutch at the track! if you are concerned and don't want to risk anything, put a couple turns of base in...
I have driven my car around on the street for years with less then 400#'s of base and 12 grams on each finger..... worked perfectly.. car made 840rwhp and weighed 3765
If you are worried about driving through the clutch on the street, just gear down and keep the revs a bit higher or add a couple turns of base! using shims or re-setting your heights is key to making sure the clutch works how you want it!
Chris Hyatt is still doing clutch work and can service all you stuff, have been working with him since his dad passed and he has been awesome!
He is a perfectionist at his work and will treat you right!
Those rams clutch's work ok, but I'm not a fan that they cant go lower then 800#'s on the BBC set up... I had a friend run one and we ended up with less then 1 turn of base and it was still hitting the tire too hard, he took it out and put back in a soft lock.
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2444316
01/31/18 10:57 PM
01/31/18 10:57 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Nice to see some rational, real world experience on this issue. Chris is one of the good guys for sure and I cannot imagine anyone being disappointed with his service.
Re: Soft Lok Clutch on the street [Re: cuda499] #2444356
01/31/18 11:41 PM
01/31/18 11:41 PM
Washington
Washington
Straight poop right here^^^^^^^^^^^. I also disagree with all that base load. Ram loves it. I have the broken parts to prove you can break parts with big plate loads.
Re: Soft Lok Clutch on the street [Re: madscientist] #2444361
01/31/18 11:50 PM
01/31/18 11:50 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
Agreeing or disagreeing with what I said???
Re: Soft Lok Clutch on the street [Re: madscientist] #2444371
02/01/18 12:03 AM
02/01/18 12:03 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
What kind of parts?
Re: Soft Lok Clutch on the street [Re: cuda499] #2444376
02/01/18 12:15 AM
02/01/18 12:15 AM
Washington
Washington
Absolutely agreeing with you. 100%.
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2444401
02/01/18 01:02 AM
02/01/18 01:02 AM
Ohio
lockjaw-express Offline
Ohio
Well, Tim Hyatt told me to run 1200 - 1800 base on the street, and 200 base on the track. He was the foremost expert, and I will listen to him!
He did tell me not to drop the clutch with high base pressures, otherwise parts breakage will happen.
He set up my clutch that I posted pics of.
Mark
PS: Yes, Chris did the inspection/adjustment plate for me on the bell I posted.
Re: Soft Lok Clutch on the street [Re: lockjaw-express] #2444407
02/01/18 01:08 AM
02/01/18 01:08 AM
Ohio
Ohio
Here are a few more pics that I took of Tim's work...Tim also put together a really nice custom manual for driving a Sofloc Clutch on the street for me, for both the Lenco in my GTX, and the Brewer A833 (Passon Geared) in my Super Bee.
I am no longer an active racer, but still like to hit the track one a year at Mopar events.
Mark
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2444434
02/01/18 02:09 AM
02/01/18 02:09 AM
Washington
Washington
I get why he likes the high base loads on the streets. Some guys will drive through the clutch because they won't downshift and think they should be able to run around in high gear at 2200 and mash the clutch.
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2444443
02/01/18 02:19 AM
02/01/18 02:19 AM
Ohio
Ohio
Madscientist, Tim told me that I should do rolling launches on the street, and absolutely NO dry burnouts! He also told me to "baby" the A833 with high base pressures.
With the Lenco, he still told me no dry burnouts, and easy on the high base pressure launches, but the lenco was more forgiving, and softer due to the internal transmission clutches.
Bottom line, he told me to use common sense ;-))
Tim mentions I his manual that I should routinely blow-out the dust in the bellhousing, and wipe it down through the access window.
Regards, Mark
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2444451
02/01/18 02:36 AM
02/01/18 02:36 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I would like to have one of those trans in my 64! Good pic on the mounts too.
Looking at the clutch, how do you determine the poundage? I know absolutely nothing on this.
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2444454
02/01/18 02:40 AM
02/01/18 02:40 AM
Ohio
Ohio
Thank you, Cudaman!
I kind of fudged up on the mount...I need two more bolts in front of the tray/mount. Just have not got around to it.
I also since added tubular CM fore/aft limiters as well that will help keep the trans in place.
Mark
Re: Soft Lok Clutch on the street [Re: lockjaw-express] #2444461
02/01/18 02:58 AM
02/01/18 02:58 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted By lockjaw-express
Thank you, Cudaman!
Mark
I've looked at a few but don't know which to stay away from, new is still way out of budget for now.
I would have to keep part of the stock crossmember too because I'm still have t-bars. Are all the good clutches long style or are some B&B?
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2444468
02/01/18 03:17 AM
02/01/18 03:17 AM
Ohio
Ohio
Tim told me that the Long style were the best for very aggressive Street and Strip. Big plus is the adjustability!
I still have the Torsion bars, and I do not notice any movement of the floor or crossmember sides.
As insurance, I am going to buy the US Cartool frame connectors, and just straddle the square couplers that are already welded in place, and also install Resto Ricks front/rear torque boxes. That should strengthen everything up even more.
Driving the ST1200 on the street really is very strange, as I keep going for the clutch between shifts...don't need to do that. Once it is going, just keep up shifting, and downshifting with foot off the gas, as it freewheels on the internal sprags.
Mark
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2444489
02/01/18 06:01 AM
02/01/18 06:01 AM
Washington
W
weedburner Offline
weedburner  Offline
W
Washington
For a street/strip application that isn't clutchless, a good diaphragm combined with an engagement buffer is going to be a far better choice than the typical SoftLoc style clutch. Less maintenance, less broken parts, and adjustable engagement without going inside the bell. No need to change settings from street to strip, no worrys about lugging the engine and burning up the clutch.
This style clutch might be something different to many of you, but look at what the NMRA Coyote Stock sealed crate engine class is doing with it. They race heads up on a pro tree, and everyone has the same engine. Both automatic and stick trans are allowed, both run at the same weight. Automatics are allowed any converter and a trans brake, sticks are required to run a minimum 10" dia single disc diaphragm clutch. I don't think there are any competitive automatics in the class, most all are sticks running the diaphragm/ClutchTamer setup. Running at 3175lbs, those $6500 NA 302ci sealed crate engines run 10.0 @ 132. The guy in this link isn't using a sealed engine, but it sets the NA Coyote record on it's 3rd pass using the exact same clutch setup, 9600rpm with a diaphragm PP... NA Coyote record run
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2444534
02/01/18 11:15 AM
02/01/18 11:15 AM
Ohio
Ohio
Weedburner, What is an engagement buffer? Diaphram Clutch? Dual disc?
Thank, Mark
Re: Soft Lok Clutch on the street [Re: lockjaw-express] #2444593
02/01/18 01:22 PM
02/01/18 01:22 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Thank, Mark
http://clutchtamer.com ?
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2444714
02/01/18 04:09 PM
02/01/18 04:09 PM
Sharpsburg Maryland
440farmer Offline
440farmer  Offline
Sharpsburg Maryland
Hmm never heard of those
Re: Soft Lok Clutch on the street [Re: lockjaw-express] #2444803
02/01/18 07:23 PM
02/01/18 07:23 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
Thank, Mark
Yeah it's a screen door damper with some fancy brackets biggrin
Gus beer
64 Plymouth Savoy
Dana 60
Page 2 of 3 1 2 3
