Re: Cam choise for 438 ?
[Re: Mopar Guy]
#2444295
01/31/18 10:35 PM
01/31/18 10:35 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Just installed the Comp Cams XE 275HL in my 432 Stroker 1971 Superbee
Edelbrock E Street 75cc - 10.3 - 1 Comp
Weiand Dual Plane
AVS 750
Transmission Rebuilt With Turbo Action Valve Body
3:91 Gears
Man , all I need now is warm weather and clean streets
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: BSB67]
#2444344
01/31/18 11:25 PM
01/31/18 11:25 PM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Both good choices. Lunati Voodoo 262/268-112 is another one.
[Re: Jeff_383]
#2444750
02/01/18 05:33 PM
02/01/18 05:33 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Put down the cam catalog down and message Dwayne Porter. He'll custom make a cam just how you want it to drive. Be honest with what you want and he'll nail it for you. Not much more money either. Yep Dwayne will spec cam that will get the most out of your combo just the way you want. He built my solid flat tappet just as I wanted. I told him my cam needs to be for 92 pump gas and I like a slightly lumpy idle and I want it to make a lot of power. He nailed it for my combo. Ron
