Aluminum Master Cylinder ? #2443697
01/30/18 10:23 PM
01/30/18 10:23 PM
Tucson, Arizona
clonestocker Offline OP
Tucson, Arizona
Which is the front and rear brake line coming out of the MC? Can't find my reference part. thx matt
[img] [/img]
Re: Aluminum Master Cylinder ? [Re: clonestocker] #2443703
01/30/18 10:43 PM
01/30/18 10:43 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Larger reservoir is the front brakes.
Re: Aluminum Master Cylinder ? [Re: clonestocker] #2443711
01/30/18 11:01 PM
01/30/18 11:01 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Normally the front port is for the rear brakes and rear port (closest to the firewall) is for front brakes.
Re: Aluminum Master Cylinder ? [Re: markz528] #2443780
01/31/18 12:15 AM
01/31/18 12:15 AM
Tucson, Arizona
Tucson, Arizona
Thank You guys smile matt
[img] [/img]
Re: Aluminum Master Cylinder ? [Re: clonestocker] #2444003
01/31/18 12:46 PM
01/31/18 12:46 PM
As said the larger port is always for the front brakes & will always be next to the firewall & if both are the same size then same thing, the one next to the firewall will be for the front brakes. OT If you are useing 73-76 A body calipers be sure to ask for ones for a '76 A body as they have a larger bore (2.75" as opposed to 2.60" for '73 -'75) which gives more front bias, always a good thing.
Re: Aluminum Master Cylinder ? [Re: clonestocker] #2444439
02/01/18 02:14 AM
02/01/18 02:14 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....and I'll be adding my adjustable proportioning valve on the rear line (front brakes). Just in case you needed more stuff to think about laugh2
Re: Aluminum Master Cylinder ? [Re: clonestocker] #2444503
02/01/18 08:46 AM
02/01/18 08:46 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Most of the smaller bore aluminum chrysler based master cylinders have no bias. For example, pre abs Caravans had cross braking hydraulic systems. Each port on the master cylinder controled one front brake, and the opposite rear brake.
This is not to say they cannot be used on a front to rear split system, but understand that there is no bias built into MOST of the non truck masters.
