My Journey in life
#2442765
01/29/18 10:12 AM
01/29/18 10:12 AM
Posts: 2,590 Piqua, Ohio
dodgeram440
Piqua, Ohio
I have a 2009 Journey 3.5 v6 AWD that I’m having a couple issues with.
First is a tune up. I checked at a local shop and he told me like $430. Wait, WHAT?!?!?!? $430 to change a set of plugs? He also told me it takes 3 hours and copper core plugs. Ok, now I know it’s been a while since I’ve really done any work on cars. I used to do all my own work, but these new computer controlled cars are a little more intimidating. I know it has a coil on plug ignition and the plugs are centered in the heads like a hemi so I don’t really see why it would take 3 hours. I know it’s a transverse mounted engine, but with the plugs on top, I don’t think it should be too hard to get to the back plugs.
So the questions for this are: 1, am I right thinking it shouldn’t take 3 hours and 2, does it really take copper core plugs? When I checked Autozone, it’s listing double platinum plugs. Also, what brand of plugs do you recommend? I’ve always been a diehard Champion user in my Mopars, but do they still work best in the modern engines?
The second problem is a little more complicated. Ever since we bought the car, it’s always had a heating problem inside. The are 4 vents in the dash, 2 in the center and two on each end. The 2 vents on the passenger side, one center and one near the door, have never blown hot, or even warm. It blows air just fine, just no heat. The left side has been fine, but recently even the left center has been starting to blow cooler. Even the far left by the drivers door is not as warm as it once was. Just enough to warm the driver, but anyone else in the car is out of luck.
I’ve done some checking online and I’ve found other people who have had similar issues and their fix was to simply flush out the heater core. Ok. I’ve done that before on other vehicles, but those cars didn’t have heat at all and the flush did help. My situation is different in that I do have heat, just not out of all the vents.
I guess the logical conclusion would be the blend doors on the ac/heater box. The shop I talked to wanted $80 just to check it out and diagnose it. That’s not counting any repairs. So the question is, how hard is it to get inside the dash enough to check the function of the blend doors? Do I have to pull the whole dash out or can I get to it thru the glove boxes?
Any help and advice would be greatly appreciated. Having financial issues right now and $400 just to change spark plugs is just insane, especially when using cheap copper core plugs. I need help!!!
Re: My Journey in life
[Re: dodgeram440]
#2442771
01/29/18 10:44 AM
01/29/18 10:44 AM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Why not do it your self, try pulling a plug and see just how difficult the job is. It's probably something you can handle your self.
Have a great day Iowan
"obsolete is neat"
[Re: dodgeram440]
#2442797
01/29/18 11:34 AM
01/29/18 11:34 AM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
If you feel that the price you were given to "tune up " you car is too much then by all means have at it and do it your self. I do auto and truck repair for a living and hear it a lot , wow it costs how much? shops factor in rent tools electric insurance what they pay the employees etc. it might be an easy job it might suck. do it and then tell us all how you made out. just remember the shop you went to is in business to make money. im quite sure if they did not need the money they'd be fishing instead. not to say there isn't crooks out there who will screw you but I like to think most are honest. its tough out there
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: dodgeram440]
#2442908
01/29/18 03:37 PM
01/29/18 03:37 PM
Posts: 3,365 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Call a local dealer parts desk--they will tell you what plug came factory on your ride.
Most of the oems are using platinums now because they last so long, but there are exceptions.
BTW, how do you know you need plugs unless you have pulled one or two and checked them? Under normal circumstances those factory platinums can last way over 100K. Yours might still be fine...
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: dodgeram440]
#2442930
01/29/18 04:34 PM
01/29/18 04:34 PM
dodgeram440
Piqua, Ohio
The car has 186,000 on it and I’ve never done anything in the three years I’ve had it. I’m sure it’s probably due for something. Fuel mileage is around 17-18, would like to get maybe 20 if it’s possible. I do a lot of highway driving with it. I guess I could just pull a plug and find out what is in it, but I wanted to try to get some info about it before I started anything, and maybe have the parts ready so I’m only doing it once.
Moparts used to be the best site on the web to get Mopar information, but I guess it’s gone downhill in the last couple years. Yeah, I’ve been gone a little while. No one has even bothered addressing my heat problem. Guess I’m just going to have to rip into it and find out for myself.
[Re: dodgeram440]
#2443074
01/29/18 09:29 PM
01/29/18 09:29 PM
yella71
New Jersey, USA
Im betting it has copper plugs in it as OE, mopar is famous for being cheap. I cant remember seeing platinum or iridium plugs in any Chrysler product unless some one put them in after the fact. anyway, what difference does it make what plug came from the factory in it, just buy the plugs you like that are correct for it and put them in, don't over think it. as far as the heat that's an across the board thing with mopar also... don't know what to tell you on that
89 CTD pup
[Re: yella71]
#2443194
01/30/18 02:00 AM
01/30/18 02:00 AM
Posts: 954 garnett kansas
rhad
garnett kansas
i was just involved in changing a 4.0 engine in a 07 nitro,you have to pull the intake to change the plugs on it!!fyi
my ladder of success is missing some rungs
[Re: yella71]
#2443262
01/30/18 04:24 AM
01/30/18 04:24 AM
dodgeram440
Piqua, Ohio
Im betting it has copper plugs in it as OE, mopar is famous for being cheap. I cant remember seeing platinum or iridium plugs in any Chrysler product unless some one put them in after the fact. anyway, what difference does it make what plug came from the factory in it, just buy the plugs you like that are correct for it and put them in, don't over think it. as far as the heat that's an across the board thing with mopar also... don't know what to tell you on that [quote=yella71] I get that using brand names comes down to a personal preference. For example, I wouldn’t use Bosch plugs in a lawn mower. Those things are just absolute junk. But I have seen where certain brands work better in certain makes: ACDelco works best in GM cars, I’ve always used Champions in my older Mopars, but I’m not familiar with these modern cars at all. And as far as copper vs platinum, there is a big difference. If you use copper in place of platinum, you’ll burn the plugs up in no time at all because the ignition burns so hot. Platinum might work ok in place of copper, but the ignition isn’t as strong and may not give a hot enough spark. Haven’t called the dealer about it, but the part store websites only list platinum or iridium, so I can’t see the factory using copper.
[Re: rhad]
#2443263
01/30/18 04:27 AM
01/30/18 04:27 AM
dodgeram440
Piqua, Ohio
i was just involved in changing a 4.0 engine in a 07 nitro,you have to pull the intake to change the plugs on it!!fyi This is the kind of info I’m looking for. I was avoiding opening the hood right now because it’s cold as hell here right now and I hate opening the hood on this thing. It’s so depressing. So now I’m going to have to open it, pull the blasted engine cover off and confirm that the intake sits over the backside plugs. Thanks.
[Re: a12rag]
#2443265
01/30/18 04:29 AM
01/30/18 04:29 AM
dodgeram440
Piqua, Ohio
check the journey forum . . . am sure they have answers there . . . as for the plugs, check with dealership for factory oem . . . my 06 Magnum RT AWD with 5.7 hemi, uses copper plugs. Do you have a link for this Journey forum? Thanks.
[Re: dodgeram440]
#2443285
01/30/18 09:39 AM
01/30/18 09:39 AM
Posts: 21,050 Niles , Ohio
therocks
Niles , Ohio
My 12 has the 3.6.Its a night mare to change plugs Has 91K on it now.probally sprijg it will get new plugs.IIRC the 3.5 should not be that bad .Been a while since Ive looked at one though.I guess the rear struts are a pain also.Ill probally change them this spring also.Rocky
Chrysler Firepower
[Re: DaytonaTurbo]
#2443349
01/30/18 12:53 PM
01/30/18 12:53 PM
Posts: 4,369 Michigan
MarkZ
Worthy
Worthy
If it makes you feel any better, a guy I work with was quoted 1k yesterday by the local dodge dealer to change the alternator in his caliber. He looked it on online and his options are to either go from the top and remove the power steering pump, undo a motor mount and push the engine back or go from the bottom, remove the shields and covers, remove the a/c compressor and wiggle it out. Another brilliant piece of chrysler engineering. This is bringing back some PTSD for me. I owned one of those turds and the alternator died a day before Easter. I replaced it myself and had to go through the bottom exactly how you described, so I was only out the $220 for the alternator. Took me six hours since there were no service manuals because Chrysler wouldn't license Haynes or Chiltons to make one for that line at the time. To compound it all, the alternator itself was fine. What failed was the damn clutch. Who the hell puts a clutch on an alternator?!
[Re: MarkZ]
#2443362
01/30/18 01:18 PM
01/30/18 01:18 PM
DaytonaTurbo
Manitoba, Canada
He's going to do his himself as well. He's a mechanic at the shop I work at but he's down to only one car for him and his wife/kid so he thought he would ask the dodge dealer how much just to see if if would be worth it. They quoted $500 for the alternator and $600 for labor. He bought an alternator for $230 from the local parts store and now needs to decide when to bring it in for the day of four letter words.
[Re: DaytonaTurbo]
#2443394
01/30/18 02:04 PM
01/30/18 02:04 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
moparts is still a great site, patients is a virtue. Used to be mostly for vintage tin. It's slowly getting acclimated to the modern "JUNK" Maybe we need two tech forums now. I really miss the vintage stuff on the truck pages. Modern stuff to me sounds a lot like plug and play tech. This is why I still drive '70s beaters for daily driver werk. We buy used minivans for the 'ole gal. She likes 'em. Besides tires and brakes, all werk is done at shops. To me, they are throw a ways. I am not capable of, or willing to learn how, to deal with modern stuff. My local shop wants $300+ for v-6 spark plug replacement. $85 an hour shop rate plus parts. They need to remove the entire windshield wiper assembly to get at the rear plugs. We had a 2000 Sport that ran up to 295,000 + miles. Had the plugs changed in it. The tech said the electrodes were gone. Figured they were original. Dash smoked itself 5 days later. She keeps getting the throw away minis and I drive my 76 pick-up year round. Yes it's rusted but pull the choke and it starts. Everybody is happy here. Just one Old fartz opinion.
I have mechanical Aptitude. I can screw up anything.
[Re: DaytonaTurbo]
#2443496
01/30/18 04:16 PM
01/30/18 04:16 PM
dodgeram440
Piqua, Ohio
Ride it out until spring then get rid of it. I personally know 4 people who have had the misfortune of owning a Journey. They are JUNK JUNK JUNK.
2 minutes of searching shows this is a common problem with these journeys. Sounds like either one of the electric blend door motor actuators is bad or the plastic shaft the actuator rotates has snapped. We are planning to get rid of it as soon as my wife gets the settlement from an accident she had. Some rocket scientist pulled out in front of her and she t-boned him. Fortunately she wasn't going very fast and only scuffed the bumper on our car. Messed his up bad. I am a little concerned though that the air bags didn't go off, but then that would have totaled the car. We have had battery issues with this car for a long time. I cant tell you how many times the battery has been replaced. And every time they replace the battery they have to fix the cables and wires around it because they are loose or "messed up" somehow. But its the same dealership that has replaced the battery every time, so I have to wonder what they are really doing. The same dealership also fixed an issue with the AWD system and in the process messed up the exhaust to where it was slightly louder than it was. the tech tried to claim that the noise level was common for all AWD Journeys, but it wasn't that loud when we brought it in. My wife took it to another dealership who found that an exhaust flange had been clocked wrong. Fixed that and it is quiet now. So I don't have a lot of faith in my local dealership, but we use them because they are affiliated with the car lot we bought the car from and we can sometimes work a payment deal thru them for the repairs. Don't think we will be able to do that for the tune-up or the heat problem. Sounds like we will just have to hope for an early spring. Of course, w live in Ohio where if you don't like the weather just wait 5 minutes, it will change.
