Re: thumperdart vs andy's fi
[Re: dodger mope]
#2443089
01/29/18 10:31 PM
01/29/18 10:31 PM
Posts: 31,046 Oregon
AndyF
The system that I'm putting on my Duster is top of the line Holley stuff. I'm not sure what the total cost is, maybe around $5000. But you don't need a distributor, crank trigger, carb, ignition box, coil, racepak, gauges, etc. So if you are starting from scratch it is about a wash.
Plus it is a cleaner install. Getting rid of all of the gauges, and misc ignition stuff like start retard, two step, high speed retard, etc. is a benefit to me.
[Re: JACK1440]
#2443375
01/30/18 01:41 PM
01/30/18 01:41 PM
Posts: 4,457 Washington
madscientist
Washington
What about mechanical injection like a Ron's Toilet bowl? Two totally different systems.
[Re: MattW]
#2443376
01/30/18 01:42 PM
01/30/18 01:42 PM
madscientist
Washington
Both fully sorted out systems, the carb makes a hair more peak power. Now EFI has infinite adjustability, mid range, cold starts, MPG, Not washing out cylinders on start up, ect. Carbs are simple to install. EFI requires much more. Matt Who gets fuel wash on start up? The only time I've seen that was with a choke. I haven't run a choke since 1983.
[Re: AndyF]
#2443402
01/30/18 02:18 PM
01/30/18 02:18 PM
Thumperdart
State of confusion
Plus it is a cleaner install. Getting rid of all of the gauges, and misc ignition stuff like start retard, two step, high speed retard, etc. is a benefit to me. I can build, test and sell a Dommy that can and DID win Drag Week and get 15+ mpg's for $1,200..............
[Re: dodger mope]
#2443435
01/30/18 03:02 PM
01/30/18 03:02 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I think the carb atomized the fuel, where the EFI is injecting un-atomized fuel which would make the EFI fuel harder to burn?
On a street car, the self-tuning of the EFI is really nice. Around here in Colorado a drive can change in altitude quite a bit. At the track, the carb seems better, but you only have to tune for WOT.
Seems the cost of FI is starting to come down to be competitive with carbs (at least the higher end versions), and you don't have to invest in all the various carb tuning parts like jets, power valves, accelerator pump cams, discharge nozzles, idle and air bleeds, gaskets, and time (or having a shop tune the car.)
The cost of the fuel delivery systems don't seem too much different in costs? In fact I spent more on the fuel system for the carb setup than the EFI setup. The EFI pump was less expensive and the EFI came with the regulator where it cost me extra for the carb setup.
[Re: JACK1440]
#2443547
01/30/18 05:37 PM
01/30/18 05:37 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
What about mechanical injection like a Ron's Toilet bowl? Since there is no accelerater pumps, a toilet or any mechanical constant flow system would be a nightmare on the street. Super fat idle, fuel draining into the cylinders on shutdown, and heavy wear from washing the cylinders,plus gas contaminating the oil. Trying to get a decent air fuel ratio st part throttle would be quite troublesome as well.
[Re: Thumperdart]
#2443694
01/30/18 10:18 PM
01/30/18 10:18 PM
Posts: 2,826 NY usa
540challenger
NY usa
Plus it is a cleaner install. Getting rid of all of the gauges, and misc ignition stuff like start retard, two step, high speed retard, etc. is a benefit to me. I can build, test and sell a Dommy that can and DID win Drag Week and get 15+ mpg's for $1,200.............. unless your looking at a multi port efi, throttle body injection system run the same price.
[Re: dodger mope]
#2443993
01/31/18 12:30 PM
01/31/18 12:30 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Well I quoted REAL WORLD dyno and on track info from a class that is NOT pro stock and is very cutting edge. I know most don't care but guys running NA10.5 are on the cutting edge of engine development. Most everyone is using big name builders and the best parts money can buy all the while pushing the envelope as far as they can to make power within the rules. We have everything from inline wedge headed small blocks, to "conventional headed" BBC's making 1300+hp to spread port small blocks, to the fastest Pontiacs in the country making BIG HP and beyond. Most these guys will spend what it takes and take the time it requires to run up front. IF EFI was faster on track I feel pretty confident many would already be making the leap if there was something there. I salute Leonard and his efforts. He is a leader in innovation and not afraid to tackle something new. But he will admit it has not been easy and still is waiting to eclipse the ET he had with a carb.
[Re: dodger mope]
#2444035
01/31/18 01:54 PM
01/31/18 01:54 PM
Posts: 200 AB
Efidart
AB
So many experts chiming in on EFI... I tune both and slightly more carbs on the dyno. Carb changes are usually absolute. Simple One change, one result. Won't be entirely perfect everywhere but you can make them pretty damn close. EFI will only be superior when you have a good tuner and granted they know what they are doing. A half ass self learned EFI system vs a perfectly tuned carb. Wonder which will be better? Maybe the better way to argue this one is- Well mechanical fuel injection is better. All the top fuel cars run it and they are the fastest!!!....
TT Predator headed 572 7 Second Street Car. Fastest Mopar Drag Week 2015 Fastest Mopar & Dodge Drag Week 2017 Pro Street Power Adder Champion Drag Week 2017
[Re: dodger mope]
#2444167
01/31/18 06:25 PM
01/31/18 06:25 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Be fun to see some of the top secret info for the year NASCAR switched over, probably hundreds of thousands of dyno tests that should show a trend, maybe plot on a graph hp 5 years before and after the switch so you can see how much power was naturally increasing VS a blip for the year they switched. Of course NASCAR has to worry about fuel miledge as well and there is just no way a carb can match it, you can't cut fuel on a carb when coasting, braking, lean it out a little to try and make one last lap on your fuel...
[Re: madscientist]
#2444269
01/31/18 10:05 PM
01/31/18 10:05 PM
Posts: 12,395 Taxes & Virus's R-US, NY
Dragula
Ditto...I have already done my own back to back track testing....Carb wins on ET if used on the same manifold. Some guys see an increase in mid range horsepower with efi, but a dyno will fly right by that....
[Re: HotRodDave]
#2444290
01/31/18 10:30 PM
01/31/18 10:30 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Of course NASCAR has to worry about fuel miledge as well and there is just no way a carb can match it, you can't cut fuel on a carb when coasting, braking, lean it out a little to try and make one last lap on your fuel... Don't be so sure. Rochester E-jets were doing that back in the 80's.
