Guys with Bridgeports at Home #2442423
01/28/18 08:34 PM
01/28/18 08:34 PM
Smyrna, South Carolina
STEFF Offline OP
STEFF  Offline OP
What are you using to go from 220 single phase to 230 3 phase? Static Phase Converter or VFD?
Re: Guys with Bridgeports at Home [Re: STEFF] #2442431
01/28/18 08:45 PM
01/28/18 08:45 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
rotary
Re: Guys with Bridgeports at Home [Re: STEFF] #2442434
01/28/18 08:49 PM
01/28/18 08:49 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
VFD but it must connect directly to the motor, no contacters.
I wired the VFD to the motor and removed all the wiring, contacters, transformers etc. from the big wiring box and rewired the power feed, coolant pump (new 110V) and lights to 110V.
Mine has the Varispeed head so I use it to control spindle speed and set the VFD to 60Hz.
Re: Guys with Bridgeports at Home [Re: STEFF] #2442443
01/28/18 09:04 PM
01/28/18 09:04 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Hands down - VFD. You want the variable speed and the braking capability of the VFD.
Foe mine, I replaced the original 1 hp motor with a 3 hp aluminum frame motor. I think I paid around $250 for the motor. I went with the 3 hp to make up for lost torque because I went with a single pulley - this way no more changing belt position to get a wide range of speed. Leave it in a high speed position and use the VFD to lower the speed.
You have a few options for braking with a VFD. The best solution is to use a dynamic braking resistor. I use DC injection - not as good but is decent and easier to implement.
Don't plan on listening to AM radio when the VFD is on................
Re: Guys with Bridgeports at Home [Re: PC-CHARGER] #2442451
01/28/18 09:14 PM
01/28/18 09:14 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
That's not really true. If the drive is closely rated to the motor size, then the drive will trip on over-current if you close the contactor when the drive is on. If the drive is oversized, then closing the contactor while the drive is on won't hurt a thing. Neither the motor or drive would care, but in a single motor application like this it does not make sense to do this.
For example, my surface grinder spindle is a 1 hp motor. The coolant pump is 1/6 hp. I run both off of a single 1 hp drive (I don't exceed the drive rated amps). I slam the coolant pump on/off at will with a contactor when the drive is running the spindle. Works absolutely fine.
The trick is the drive must be able to provide the inrush current and the drive needs to be set up in volts/hertz mode. For a mill you prefer sensorless vector mode because you don't lose torque at low speeds like you do in volts/hertz mode. No issues if you don't run in volts/hertz mode at low speeds.
My mill is volts/hertz (so old it don't have sensorless vector mode) and I can stall the motor at very low speeds.
Re: Guys with Bridgeports at Home [Re: STEFF] #2442460
01/28/18 09:24 PM
01/28/18 09:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Changed the motor to single phase.
Re: Guys with Bridgeports at Home [Re: STEFF] #2442462
01/28/18 09:25 PM
01/28/18 09:25 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I built a rotary phase converter for under $20 using cast off parts that I scrounged: a 5 horse 3 phase motor for the converter, a 1/2 horse 110 motor to start the converter motor spinning, and then bought 2 pulleys and a belt to connect them.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Guys with Bridgeports at Home [Re: STEFF] #2442463
01/28/18 09:28 PM
01/28/18 09:28 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I’ve used the phase-a-matic converters in the past. I would get 2 to 3 years out of them. Fixed one a few times. Finally went with a rotary phase converter. Machines run much smoother, and reversing on demand works perfectly. No comparison between the two on performance.
Re: Guys with Bridgeports at Home [Re: STEFF] #2442468
01/28/18 09:33 PM
01/28/18 09:33 PM
STEFF Offline OP
STEFF  Offline OP
I have a 2hp 230 3 phase motor, 60hz, and a vfd rated for 2hp. I've set the parameters in the vfd for the hp, voltage and hertz. I go to click the fwd/rev switch to turn the motor on and the vfd overload faults. I have the variable speed on the vfd set to 60hz. Ive tried lower settings, still get the overload fault. Motor is freshly rebuilt, spins freely.
Re: Guys with Bridgeports at Home [Re: STEFF] #2442487
01/28/18 09:52 PM
01/28/18 09:52 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
steff,
just swap the motor. on the older bridgeports you had either a bunch of pulleys and needed to swap belts or the variable pulley to change the spindle speed. either used a single phase motor run at 60hz. if you run a regular 3 phase motor with a vfd, you will lose torque at low rpms or at higher rpms if you over run it. if you run it at 60hz you don't need a vfd. buy a single phase motor at the correct rpm and be done with it. surpluscenter.com is usually where I get my motors. that or ebay.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Guys with Bridgeports at Home [Re: Jerry] #2442491
01/28/18 09:58 PM
01/28/18 09:58 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Originally Posted By Jerry
steff,
iagree
Re: Guys with Bridgeports at Home [Re: STEFF] #2442508
01/28/18 10:23 PM
01/28/18 10:23 PM
STEFF Offline OP
STEFF  Offline OP
Jerry, this mill is not terribly old. It has the adjustable speed knob on it. There is one big drive belt with a spring loaded pulley on the motor. I just had the motor rebuilt from 480 3 phase to 230 3 phase, due to the extended shaft on the motor and bearing support at end of motor shaft. Figured it would be less hassle than finding an exact replacement motor with the exact shaft.
Re: Guys with Bridgeports at Home [Re: STEFF] #2442514
01/28/18 10:39 PM
01/28/18 10:39 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I use a static converter on my Bridgeport. No issues.
I use a rotary on my CNC.
Re: Guys with Bridgeports at Home [Re: STEFF] #2442525
01/28/18 11:06 PM
01/28/18 11:06 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
A little bit of rewiring and Steff will be fine!
A little birdie told me............. whistling
Re: Guys with Bridgeports at Home [Re: STEFF] #2442542
01/28/18 11:33 PM
01/28/18 11:33 PM
STEFF Offline OP
STEFF  Offline OP
Thanx Mark! Email sent.
Re: Guys with Bridgeports at Home [Re: STEFF] #2442573
01/29/18 12:22 AM
01/29/18 12:22 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I want one so BAD, hate to hijack but,
I have a 50 hp Roto-Phase converter for my other 3 ph machines, so am I good to go? You guys are talking way over my head.
PS. I want one I can put an engine block in.
Re: Guys with Bridgeports at Home [Re: STEFF] #2442588
01/29/18 12:42 AM
01/29/18 12:42 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
We have 12 of bridgeport and other brand Mills at work. I can use any of them when I need to but I still want one for at home someday along with a nice lathe.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Guys with Bridgeports at Home [Re: STEFF] #2442600
01/29/18 12:56 AM
01/29/18 12:56 AM
STEFF Offline OP
STEFF  Offline OP
A Lathe is on my list and then I will be self sufficient.
Re: Guys with Bridgeports at Home [Re: markz528] #2442621
01/29/18 01:16 AM
01/29/18 01:16 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
What kind of rewiring are we talking about here. Id be interested to know? up
Re: Guys with Bridgeports at Home [Re: cudaman1969] #2442642
01/29/18 01:42 AM
01/29/18 01:42 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Your good to go for anything with a motor size up to 25 HP
