Re: Auto trans I'd
[Re: cudaman1969]
#2442501
01/28/18 10:14 PM
01/28/18 10:14 PM
Posts: 17,547 Las Vegas, NV
6bblgt
Las Vegas, NV
Need the experts on numbers. I have a 727 b trans, build date is Oct 68. After looking in my 69 service manual the vin is weird, the reason for this post. Vin- WH23F9A20095 book said 69 only did the whole vin on case. Coronet 440 high end two door hardtop, the F is what gets me, SM says F is a 318 but trans is for a big block (I know the difference). Is this a common mistake or am I reading it wrong? Case serial # PK2892091L 2633 is it missing a digit of the sequence number? I've seen other "typos" - one 727 was "XS29F9xxxxxxx" - I'll have to see if I can find it - must've been stamped on Friday
Re: Auto trans I'd
[Re: 6bblgt]
#2442565
01/29/18 12:11 AM
01/29/18 12:11 AM
Posts: 8,653 fredericksburg,va
cudaman1969
fredericksburg,va
Need the experts on numbers. I have a 727 b trans, build date is Oct 68. After looking in my 69 service manual the vin is weird, the reason for this post. Vin- WH23F9A20095 book said 69 only did the whole vin on case. Coronet 440 high end two door hardtop, the F is what gets me, SM says F is a 318 but trans is for a big block (I know the difference). Is this a common mistake or am I reading it wrong? Case serial # PK2892091L 2633 is it missing a digit of the sequence number? I've seen other "typos" - one 727 was "XS29F9xxxxxxx" - I'll have to see if I can find it - must've been stamped on Friday Yea meant to mention that, only 5 numbers, I'm thinking that explains the F too.
Re: Auto trans I'd
[Re: cudaman1969]
#2442947
01/29/18 04:58 PM
01/29/18 04:58 PM
6bblgt
Las Vegas, NV
just a simpler "typo" hopefully it is the only digit wrong (F VS. H) the part number is probably correct, wrong part number stampings would've caused chaos 1969 non-HP 383 4bbl B/C-bodies & 383/440 A-bodies
