Re: thrust bearing tight
[Re: fastfish451]
#2441551
01/27/18 04:00 PM
01/27/18 04:00 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Did you "set" the crank properly after installation?
[Re: fastfish451]
#2441552
01/27/18 04:02 PM
01/27/18 04:02 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
[Re: fastfish451]
#2442418
01/28/18 08:29 PM
01/28/18 08:29 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I just ran into the same situation with a stock 400 block going to a stroker with King main bearings. Crank was binding with thrust bearing torqued down. But when i removed the bearing, i saw a few shiny spots, so i just polished them down with a bearing scraper.
Instantly freed the crank up and got me .005”. I dont know, sometimes certain high spots must develop when the cap is torqued down to spec i guess. But all it took was slight polishing in a few tiny areas. Btw, the block was align bored and honed with the new billit steel caps.
