What device 2 mount Tach on column the old school way? #2441283
01/26/18 11:03 PM
01/26/18 11:03 PM
fullmetaljacket Offline OP
My friend "The Palm Reader" who is ready to debut a beautiful 68' Coronet Wanna-Bee this Spring wants to run a tach mounted onto the steering column just as it may have been as a day two modification back in the day.
Anyone here remembers or knows for sure what dudes used to mount the tach there?
Did they even have worm gear straps back then?
Re: What device 2 mount Tach on column the old school way? [Re: fullmetaljacket] #2441287
01/26/18 11:14 PM
01/26/18 11:14 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Yep. Radiator hose clamp.
Re: What device 2 mount Tach on column the old school way? [Re: FastmOp] #2441298
01/26/18 11:37 PM
01/26/18 11:37 PM
Were there such a thing as a worm gear style radiator hose clamp back in 68'?
or did they have a different design?
Pictures?
He just wants to be period correct and also driving me crazy period! LOL.
Re: What device 2 mount Tach on column the old school way? [Re: fullmetaljacket] #2441310
01/27/18 12:04 AM
01/27/18 12:04 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
That's what we used. Don't forget the prism tape on the dash, the Kraco 8 track, woodpecker header mufflers, the rear end housing painted white and air shocks pumped up to 150# so the M50s don't rub.
Re: What device 2 mount Tach on column the old school way? [Re: CMcAllister] #2441317
01/27/18 12:17 AM
01/27/18 12:17 AM
LOL.
Nah, his car will be very spartan to say the least. Kind of a [censored] child of a F.A.S.T type car for the street. Warmed over Elephant built by Dave Dudek.
Re: What device 2 mount Tach on column the old school way? [Re: fullmetaljacket] #2441322
01/27/18 12:39 AM
01/27/18 12:39 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Thin strip of rubber/vinyl/electrical tape where the clamp could rub the column's paint, and a hose clamp. Probably where I learned to trim clamp ends of excess length. Some guys screwed them to the column as long as the screw threads didn't interfere with the column's guts.
Re: What device 2 mount Tach on column the old school way? [Re: fullmetaljacket] #2441431
01/27/18 11:18 AM
01/27/18 11:18 AM
Benton, IL.
DaveRS23 Offline
Master of nothing...
DaveRS23  Offline
Benton, IL.
I have the tach mounted on the column of my current Cuda the same way that I had it mounted on my first car back in the early 70s. Radiator clamp.
Back then I used black electrical tape under it to keep from scratching the column's paint. Today, I slip the clamp into some heat shrink.
Master, again and still
Re: What device 2 mount Tach on column the old school way? [Re: CMcAllister] #2441432
01/27/18 11:24 AM
01/27/18 11:24 AM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
McCreary M50's hanging out of the wheel well , with shackles so long that they had to remove the rear valence on my Challenger R/T when I first bought it. wave
Re: What device 2 mount Tach on column the old school way? [Re: fullmetaljacket] #2441448
01/27/18 12:07 PM
01/27/18 12:07 PM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
hose clamp on my 69 charger forever. if a guy couldn't find one big enough, two of 'em were screwed together to make one big enough to go around the column and mount, which, at the time, most had a slot the clamp fit in perfectly. i hung out with some guys at the international harvester truck garage-remember those "corn-binder" big trucks? i got some super big clamps there and cut them to the exact length i needed. as they were stainless, there was no need to worry about them rusting, although several guys painted them to match the column color, making the tach appear to just "be there".
beer
Re: What device 2 mount Tach on column the old school way? [Re: fullmetaljacket] #2441486
01/27/18 01:12 PM
01/27/18 01:12 PM
Ohio
lockjaw-express Offline
Ohio
Two self taping short screws, and a hose clamp...been doing that way for many years. If you don’t use the short screws, it will slide and move around.
Re: What device 2 mount Tach on column the old school way? [Re: lockjaw-express] #2441492
01/27/18 01:19 PM
01/27/18 01:19 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Hose clamp on my Dart been there for over 35 years!
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: What device 2 mount Tach on column the old school way? [Re: moparts] #2441601
01/27/18 04:07 PM
01/27/18 04:07 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
He did say "period correct".
Re: What device 2 mount Tach on column the old school way? [Re: fullmetaljacket] #2441655
01/27/18 05:34 PM
01/27/18 05:34 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
What kind of tach is he using Lee? Hopefully a Sun or SW!
This is as old-school as it gets. Obviously the column mount one has the curved bottom... yes, I said curved bottom.
SK has large T-bolt clamps if he wants something other than a hose clamp.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: What device 2 mount Tach on column the old school way? [Re: fullmetaljacket] #2441660
01/27/18 05:47 PM
01/27/18 05:47 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
This is real old school.
Re: What device 2 mount Tach on column the old school way? [Re: CMcAllister] #2441666
01/27/18 06:20 PM
01/27/18 06:20 PM
Wow! what a cool tach.
RMCHGR, Yes, he's running an retro SW unit with the bottom curved for the column. We just weren't sure what was used back when to mount them.
You know how some movies will have graffiti in the back ground for a New York scene set in the early 70's and the graffiti will be of the 80's and 90's. I catch the spoils every time.
I myself wish Super/Stock Formula 1 front runner tires were reproduced. I'd be first on line for them.
Re: What device 2 mount Tach on column the old school way? [Re: fullmetaljacket] #2441683
01/27/18 07:00 PM
01/27/18 07:00 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
SW = good. And as long as its not a Monster tach and shift lite... apimp
'71 Duster
'72 Challenger
'17 Ram 1500
Re: What device 2 mount Tach on column the old school way? [Re: RMCHRGR] #2441741
01/27/18 09:21 PM
01/27/18 09:21 PM
N.Y.
sixpacksteve Offline
N.Y.
wrap a thin piece of rubber under the hose clamp and don't forget traction bars!
Hell Hath No Fury Like Mine
Re: What device 2 mount Tach on column the old school way? [Re: fullmetaljacket] #2441875
01/27/18 11:58 PM
01/27/18 11:58 PM
WI
Brewzer67 Offline
Brewzer67  Offline
WI
Put heat shrink tubing on the clamp. It keeps it from marking your column.
Re: What device 2 mount Tach on column the old school way? [Re: fullmetaljacket] #2442063
01/28/18 04:07 AM
01/28/18 04:07 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
That's how mine is mounted in my 63. I just use the big style rad hose clamp. Ron
Re: What device 2 mount Tach on column the old school way? [Re: fullmetaljacket] #2442158
01/28/18 12:03 PM
01/28/18 12:03 PM
moparx Offline
moparx  Offline
my one buddy's dad was one of the first formula one dealers when they came out. F-60's on a 6" rim front and M-50's with a 10" rear rim on the back of my charger with a slightly larger sway bar on the front [can't remember what it was originally from, but it needed modified to fit], and a home made cross tube attached to slapper bars on the rear made my charger a real turn carver on the street, and formula front runners on 4" cragar ss rims for NU-BE dragstrip duty along with mccreary 29x11.00 slicks on 7" stocker rims. long time ago though........
beer
Re: What device 2 mount Tach on column the old school way? [Re: fullmetaljacket] #2442190
01/28/18 12:33 PM
01/28/18 12:33 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
As far as I know, the car in question isn't a true "day 2" car; no decals, mags, headers, hi jackers, etc. It's more of a F.A.S.T. type deal. Not sure you could call it a sleeper but it's pretty stock looking at a casual glance. I believe the tach would be just a small period-correct add on touch.
But as for the day 2 tire discussion - Pro Trac tires are available from Coker. Pretty similar to the Formula Super Stock tires without the RWL.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: What device 2 mount Tach on column the old school way? [Re: RMCHRGR] #2442212
01/28/18 01:09 PM
01/28/18 01:09 PM
The car in question is all STOCK. Just a tach add on. LOL.
Seriously though, the car might as be stock being that a 4 speed needs to be acquainted with after so many years.
He's keeping to the F.A.S.T class tire looks, but he's way from learning what those F.A.S.T guys from Richmond high know and do already.
Basically a F.A.S.T car on the street.
And no, no Monster tach for this one.
Love that Don Garlits Americana tach shown above.
Re: What device 2 mount Tach on column the old school way? [Re: fullmetaljacket] #2442236
01/28/18 01:38 PM
01/28/18 01:38 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I did the tach on the column for years and then mounted a monster on the Dash pad. Reality was I couldn't see ANY gauges when the go pedal was fully depressed!! Now I just use a shift light whistling
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: What device 2 mount Tach on column the old school way? [Re: hemi-itis] #2442751
01/29/18 07:32 AM
01/29/18 07:32 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Funny as even though I have my tach mounted where I can easily see it I rarely use it when racing. I usually look at it on the line as I come up on the converter a little but no matter what I tell myself I usually always shift by the feel , sound and pull of the eng. My brother used to get mad at me when he would ask me what I shift at and I would say .....when it feels right. Ron
