Re: Building a HP 440 with Factory Manifolds [Re: bobby66] #2440498
01/25/18 12:40 PM
01/25/18 12:40 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Originally Posted By bobby66
How do you guys get around the plug clearance problem with Edlebrock heads and HP manifolds? Don't the angled plugs get really close to the heat?
You don't. I kept frying the #7 plug boot. It was my own stupid fault for buying Edelbrock heads. I knew there was better heads on the market with straight plugs. In the end this was my solution:
Shorty headers as I didn't want the headache of long tubes. Decided to have them made out of stainless while I was at it.
Re: Building a HP 440 with Factory Manifolds [Re: Mr D21] #2440507
01/25/18 01:02 PM
01/25/18 01:02 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Edelbrock E Street 84cc heads have straight plugs.
Re: Building a HP 440 with Factory Manifolds [Re: bobby66] #2440544
01/25/18 02:05 PM
01/25/18 02:05 PM
AndyF Online content
AndyF  Online Content
I used the Mopar 452 heads (straight plug version of the Edelbrocks). There is a lot more clearance with the straight plug heads. Previously I had run the angle plug heads and had problems burning up one or two of the spark plug leads so I switched heads.
What you really want from a clearance standpoint is an angle plug head on the driver side and a straight plug head on the pass side. That would work the best for the spark plug wires.
Re: Building a HP 440 with Factory Manifolds [Re: AndyF] #2440557
01/25/18 02:34 PM
01/25/18 02:34 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Interesting. Maybe I'll snag one 452 head for the passenger side.
Re: Building a HP 440 with Factory Manifolds [Re: Von] #2440565
01/25/18 02:53 PM
01/25/18 02:53 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted By Von
Bsb...
I've always felt your combo is one of the most impressive combos on this board.👍👍
Re: Building a HP 440 with Factory Manifolds [Re: Mr D21] #2440734
01/25/18 09:47 PM
01/25/18 09:47 PM
New York
polyspheric Offline
polyspheric  Offline
New York
dogdays on point, as usual.
Shorties for street = excellent. Equal length highly over-rated for a engine with limited RPM and "warm" cam with moderate OL and wide LSA.
More trouble, more $$$, less efficient than shorties (but better than manifolds and very tight for clearance): fabrication from "weld ells".
Boffin Emeritus
Re: Building a HP 440 with Factory Manifolds [Re: Mr D21] #2440789
01/26/18 12:07 AM
01/26/18 12:07 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
http://www.hughesengines.com/TechArticles/10hpmanifoldshookersupercompheadersonbigblockangle.php
Spark Plug Clearance Click On Link
I am running the 75cc E Street Heads - I have not seen any issues yet but not a lot of miles with the HP Manifolds
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Building a HP 440 with Factory Manifolds [Re: Mr D21] #2441142
01/26/18 07:21 PM
01/26/18 07:21 PM
california
Mr D21 Offline OP
Mr D21  Offline OP
california
Great replies - thanks everyone keep them coming,,,,
Re: Building a HP 440 with Factory Manifolds [Re: fast68plymouth] #2443190
01/30/18 01:51 AM
01/30/18 01:51 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Are the 75cc heads angle-plug? The Edelbrock website shows angle plugs on the E-Street page, and I can't find any other pics of these heads on their website.
Subscribed, as I'm building a HP manifold engine myself...
Clair
Re: Building a HP 440 with Factory Manifolds [Re: AndyF] #2443289
01/30/18 09:56 AM
01/30/18 09:56 AM
PA
Harry's Taxi 2 Offline
PA
Andy, a little off the topic, but where did you get those exhaust gaskets?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Building a HP 440 with Factory Manifolds [Re: Mr D21] #2443404
01/30/18 02:22 PM
01/30/18 02:22 PM
Those are motor home gaskets. They extend upwards a few inches to protect the valve cover and valve cover gasket from the heat. I always use them with HP manifolds.
Re: Building a HP 440 with Factory Manifolds [Re: Clair_Davis] #2443560
01/30/18 06:10 PM
01/30/18 06:10 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Clair
Yes
Siberian Huskies
Re: Building a HP 440 with Factory Manifolds [Re: Mr D21] #2443585
01/30/18 06:54 PM
01/30/18 06:54 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Fel Pro MS90425 Exhaust Manifold Gaskets With Heat Shields
Siberian Huskies
Re: Building a HP 440 with Factory Manifolds [Re: bee1971] #2443595
01/30/18 07:06 PM
01/30/18 07:06 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Clair
Yes
Ok, I didn’t ask that well- it looks like all the e-sreets are angle plug on the EB website, but some are clearly straight. Is the EB website wrong, and are the 84cc heads actually straight? Angle plugs don’t work with c-body hp’s and I need to go with straight plugs.
Thanks,
Clair
Re: Building a HP 440 with Factory Manifolds [Re: Mr D21] #2443608
01/30/18 07:35 PM
01/30/18 07:35 PM
So. Burlington, Vt.
So. Burlington, Vt.
I don't know if the 84cc E Street heads were always straight plug, but they are now...... And there is a foot note in the catalog saying so.
The 75cc version are still angled plugs.
Re: Building a HP 440 with Factory Manifolds [Re: fast68plymouth] #2443716
01/30/18 11:13 PM
01/30/18 11:13 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Perfect, thank you! Too bad EB doesn't have that note on their e-street page - kind of important, and was going to cost them a sale. I've been banking on using the Source Stealth heads on my stock-appearing build because they were about the only straight-plug option. The USA-made E-streets also flow a little better OOTB, too.
Thanks again!
Clair
Re: Building a HP 440 with Factory Manifolds [Re: Harry's Taxi 2] #2445093
02/02/18 09:23 AM
02/02/18 09:23 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
i know that ehrenberg sells those gaskets
Is there another source ?
Re: Building a HP 440 with Factory Manifolds [Re: sogtx] #2445108
02/02/18 11:01 AM
02/02/18 11:01 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Summit shows that the Fel-Pro PN is available through them for $10. Autozone can get them for $11.
