Re: Building a HP 440 with Factory Manifolds
[Re: Mr D21]
#2439269
01/22/18 10:49 PM
01/22/18 10:49 PM
Posts: 31,325 Oregon
AndyF
Not a waste of money at all. I run a low deck 512 in my B body car. It has ported Edelbrock heads and HP cast iron manifolds. The trick is getting the right cam ground for the engine. You don't want a lot of overlap with the manifolds.
Another thing to consider is going with EFI. EFI also works great with less overlap so the two work well together. You can build a really smooth quiet engine that will pull like a freight train. Make it 500 inches with ported aluminum heads, cast iron manifolds and EFI.
[Re: AndyF]
#2439304
01/22/18 11:34 PM
01/22/18 11:34 PM
RapidRobert
Trick stuff Andy. what is the OD of the ex pipes?
[Re: Mr D21]
#2439563
01/23/18 01:53 PM
01/23/18 01:53 PM
Posts: 14,575 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I would suggest defining exactly what the goals for the build are, then determine if all the parameters can be met within the budget....... Without using headers.
Don't fall into the trap of thinking it will make just as much power without the headers....... It won't.
I've dynoed quite a few FAST builds, and I can tell you that's really the hard way to try and make power.
[Re: Mr D21]
#2439704
01/23/18 07:07 PM
01/23/18 07:07 PM
Posts: 4,221 New York
polyspheric
New York
Don't fall into the trap of thinking it will make just as much power without the headers....... It won't. This^^^
Better heads: definitely, more flow without extending cam duration.
What will help, but it's a PITA (if you can fit them at all): 1" thick steel exhaust flange as a spacer between the manifolds and the head (with longer studs). If you can't water-jet etc. you could use 3 X 3/8" common flanges each side. 1. straighter path for gas leaving the port before the turn 2. more volume inside the casting 3. keeps the pulses separated longer before merge Yes, 6" thick would be better, but...
Boffin Emeritus
[Re: AndyF]
#2439706
01/23/18 07:10 PM
01/23/18 07:10 PM
Posts: 338 Montreal Quebec
STROKIE
Montreal Quebec
[quote=AndyF]Not a waste of money at all. I run a low deck 512 in my B body car. It has ported Edelbrock heads and HP cast iron manifolds. The trick is getting the right cam ground for the engine. You don't want a lot of overlap with the manifolds. Can I ask you for a suggestion for a roller cam with cast iron manifolds (lot of overlap)... My 451 with 3.23 rear end street tires 1967 Charger run 109.26 12.87 with stock Magnum cam and I wish go roller cam with manifolds Thanks https://youtu.be/tt-x-_3jjmE
[Re: STROKIE]
#2439756
01/23/18 09:19 PM
01/23/18 09:19 PM
Posts: 259 Scatchamatoon
Saskabusa
Scatchamatoon
Can I ask you for a suggestion for a roller cam with cast iron manifolds (lot of overlap)... My 451 with 3.23 rear end street tires 1967 Charger run 109.26 12.87 with stock Magnum cam and I wish go roller cam with manifolds Thanks https://youtu.be/tt-x-_3jjmE I have a 67 Charger with a 451 low deck. Unported Stealth heads SD intake and 74 magnum exhaust manifolds and TTI head pipes. The cam is a comp 308 roller The car has ladder bars with 4500 stall and 4.1 gears. It ran 12.0 @ 111 mph I didn't run it very much in this configuration. I quickly installed a set of hooker competition headers. It has ran a best of 11.53@116 after a little bit of tuning with headers. I never drove it on the street so I am not sure what its manners are like. It seems fine in the pits, starts really well. This was not the best choice but it was what I had.
1974 Roadrunner
1967 Charger
[Re: Mr D21]
#2439770
01/23/18 09:40 PM
01/23/18 09:40 PM
Posts: 4,575 Michigan
MarkZ
Worthy
Worthy
I hate long tubes headers, but discovered I wasn't a fan of exhaust manifolds either - they really do make it a PITA to reach the plugs. I ended up having a set of shorty headers custom made with 1 7/8" primary tubes and 3" outlets. Couldn't be happier.
[Re: Mr D21]
#2439772
01/23/18 09:42 PM
01/23/18 09:42 PM
fast68plymouth
So. Burlington, Vt.
The FAST motors I've tested were all serious underachievers when considering the amount of time, effort, and $$$ invested. That's just the nature of the beast with those things, and a build not required to be legal for the class would certainly be able to bring the numbers up a bit by not having to use the stock heads and intake manifolds. However, running the non-scavanging exhaust manifolds does impose some limits on the parts choices.
[Re: Mr D21]
#2439833
01/24/18 12:09 AM
01/24/18 12:09 AM
Posts: 4,351 Prospect, PA
BSB67
Prospect, PA
It does not sound like the OP is suggesting or hoping to match header power with manifolds.
My junk is pretty simple. 120 mph at 4150 lb in a car with basically a stock factory suspension. Seems like okay power to me. If it were any faster I'd need a roll bar, and that is not going to happen. It will drive through the neighbor at 1100 rpm in third gear with no problem.
I did choose to purchase a roller cam, but here is what I did not have to purchase: headers, starter, 3" exhaust, converter, gear, tires.
Certainly not the fastest car around, but I wish I had a dollar for every header car I've spanked.
Personally, I would not put headers on a from scratch build unless I was also planning to install a roll bar.
As mentioned, it is a matter of what the OPs goals are.
[Re: Moparteacher]
#2439871
01/24/18 01:44 AM
01/24/18 01:44 AM
RapidRobert
TTI has 3" headpipes for the b-body manifolds. I have some. Nice thick flanges.
You will need the manifold casting numbers to get the correct pipes. Thank you, I will check their site.
[Re: Mr D21]
#2440145
01/24/18 04:43 PM
01/24/18 04:43 PM
dogdays
I hope you're only talking about exhaust manifolds. Extrude honing has fallen out of favor. The results aren't worth the price. I'm guessing a cost of between $50 and $100 per horsepower. https://boneheadperformance.com/extrude-honing/extrude-hone-pricing/As famous engine builder Joe Sherman said, "It is a total big waste of money==TOO BAD". Increasing flow in the cylinder head allows one to use a smaller camshaft for the same power. Getting air into the engine is more difficult than getting it out because less pressure available to push it in than to push it out. So good heads will always help. Making the engine bigger may not increase the horsepower if the engine is flow-limited, but it does move the torque curve down the rpm scale and thus the vehicle feels much stronger. So for a street driven vehicle, assuming you can get grip, the larger engine will always feel more powerful. Alternately, you can decrease the gear ratio and keep the vehicle feeling the same. R.
[Re: Mr D21]
#2440404
01/25/18 02:51 AM
01/25/18 02:51 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Bsb...
I've always felt your combo is one of the most impressive combos on this board.👍👍
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
