Ram 1500 Spindle Swap #2439547
01/23/18 02:18 PM
01/23/18 02:18 PM
Newport, Mi
Evil Spirit Offline OP
Newport, Mi
I have a 96 Ram 1500 2wd that has the "old style" wheel bearings. Has anybody switched over to use the later unit bearing style hubs? I'm trying to figure out if I find a 2000-2001 donor truck if I can just switch the spindles, rotors, calipers, pads and hubs. Rock Auto shows different ball joints, control arms, tie rod ends, etc starting in 2000, but I don't know why they made the change. Not really wanting to change the control arms if possible - the previous owner had installed new ones, along with other parts, about 30K miles ago. I would think that if the size and taper of the ball joint studs are the same between the different years it should work. I guess they might have changed something on the spindles where the tie rods mount, too. But since I need to do some brake work anyways, it would be a good time to do the swap, and I just prefer the sealed bearings, plus the options of factory wheels opens up a lot.
So, has anyone already done this swap, or knows exactly why it won't work?
Thanks, Willie
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Ram 1500 Spindle Swap [Re: Evil Spirit] #2439920
01/24/18 10:51 AM
01/24/18 10:51 AM
STL
cdstl Offline
cdstl  Offline
STL
I have the same truck. Here's an older post that I found.
http://www.ramforumz.com/archive/index.php/t-137809.html
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Ram 1500 Spindle Swap [Re: Evil Spirit] #2440369
01/25/18 02:19 AM
01/25/18 02:19 AM
Newport, Mi
Newport, Mi
Great find - THANKS
Re: Ram 1500 Spindle Swap [Re: Evil Spirit] #2745815
02/23/20 05:32 PM
02/23/20 05:32 PM
Mo.
racerx Offline
racerx  Offline
Mo.
I now this a old thread but this is what I was looking to do to my 1 st gen Ram up the power of the internet cool
Re: Ram 1500 Spindle Swap [Re: racerx] #2745838
02/23/20 06:50 PM
02/23/20 06:50 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
the question is WHY??? I change out a ton of hub bearing assemblys because they are not serviceable. the trucks we have in the fleet (at work) with the old style inner/outer bearings, races, seals that are serviceable, rarely if ever need replaced/. and when they do they are much cheaper to deal with.
Re: Ram 1500 Spindle Swap [Re: volaredon] #2745976
02/24/20 06:19 AM
02/24/20 06:19 AM
Mo.
racerx Offline
racerx  Offline
Mo.
For me..... better brakes for towing and I have the 20" wheels that I have to modify the hub bearing caps to fit .I'm still researching this wave
