Which CAM and what will my 451 CR be? Head Gasket?
#243970
03/05/09 12:23 PM
03/05/09 12:23 PM
Posts: 271 Dallas, Wisconsin
BurntOrange
Dallas, Wisconsin
I just assembled my shortblock. Want a torque monster for my '69 Fury 727 w/2.76 diff. Recommend head gasket? Compression Ratio? Cam for cruising on the highway? Voodoo 60302? 400 block 4.375 bore 3.75 stroke. Diamond 52407 pistons -12cc dished .010 below deck. 915 heads, DP4B intake. HP ex. Man. 2 1/2" ex.
Re: Which head gasket and what will my 451 CR be? Cam?
[Re: BurntOrange]
#243971
03/05/09 12:26 PM
03/05/09 12:26 PM
Posts: 4,848 Memphis
HemiRick
Memphis
I rec a steel shim as that will give you the most comp. ratio
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#243972
03/05/09 12:54 PM
03/05/09 12:54 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I'd also go standard blue Permatorques. It yields 9.6.1:1 static, with a .050 quench. The quench is not optimal, but it will still help. This also allows you to run a smaller torquey cam the gearing and weight need. You will want to run something cam-wise with at least 225°@.050.
[Re: BurntOrange]
#243975
03/05/09 02:03 PM
03/05/09 02:03 PM
RapidRobert
I think the 915's average 80 CC's. www.cometic has different thickness gaskets & there are others(which are probably cheaper) & getting proper quench is CRITICAL.
[Re: Streetwize]
#243984
03/05/09 11:19 PM
03/05/09 11:19 PM
RapidRobert
yes a D dish will quench fine. For some reason I erroneously got to thinking that you were talking about just a regular dish piston with the thin perimeter around the dish which you were not.
[Re: DaytonaTurbo]
#243989
03/08/09 10:50 PM
03/08/09 10:50 PM
BurntOrange
Dallas, Wisconsin
I can only seem to find .020 steel shim or .039-.040 head gaskets. .010 deck clearance. .049-.050 quench too much distance to work for my intended purpose? .030 too tight? Other cam ideas? Bigger w/Rhoads lifters? Much help given so far. Thanks More discussion welcome.
