Elephant ear, motor plate thickness
#243952
03/05/09 11:46 AM
03/05/09 11:46 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
What is the minimum thickness a ear or plate should be? I need as thin as possible to avoid interference with my water pump and fan assembly.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Elephant ear, motor plate thickness
[Re: Von]
#243953
03/05/09 11:48 AM
03/05/09 11:48 AM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
1/4 inch, but make sure you put in good fore/aft limiter. we have done 1/4 inch no problem with 850-900 horsepower.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
[Re: Von]
#243955
03/05/09 12:32 PM
03/05/09 12:32 PM
Posts: 13,407 Marion, South Carolina [><]
an8sec70cuda
I have a 1/4" plate on mine w/ no problems. You can mill the back side of your water pump housing to offset the thickness of the plate if you need to. CHIP
[Re: an8sec70cuda]
#243956
03/05/09 03:49 PM
03/05/09 03:49 PM
Von
NE Oklahoma
Once again, dang good info CHIP. That is exactly what I'll do.
[Re: joshking440]
#243959
03/06/09 08:27 PM
03/06/09 08:27 PM
Challenger 1
Cincinnati, Ohio
Not to Hi-Jack, but do you need for and aft locators if you run a midplate?
YES definetly.
[Re: rowin4]
#243961
03/07/09 02:41 AM
03/07/09 02:41 AM
Posts: 331 Mansfield,Ohio
Brandon70cuda
Mansfield,Ohio
Do you need a limiter if you run a motor plate with a solid transmission mount?
Depends do you like cracking tailshafts and trans cases? Cause I've always heard and been told a solid trans mount was a no no.
Granted I've seen a 9.40 hemi car run a front plate and poly trans mount and not break anything yet, but I wouldn't suggest that either.
