Re: Big Block mechanical pump for 800 Hp
[Re: bobby66]
#2439725
01/23/18 09:02 PM
01/23/18 09:02 PM
Posts: 72 WI
Brewzer67
WI
Be ready to do some serious grinding on that Clay Smith pump. Had to grind the block on my 440, ran out of room on the pump. I hit it lucky and didn't have to clearance the block at all but it is a snug fit as it sits. I did have to clearance the pump almost to one of the screws. Last motor was a little over 600hp running with this pump and held a steady 7psi all the way down the track. Hopefully it will keep up with the new motor as well. Time will tell.
[Re: bobby66]
#2439726
01/23/18 09:06 PM
01/23/18 09:06 PM
Posts: 3,392 cheshire, ct
davesmopars
cheshire, ct
Be ready to do some serious grinding on that Clay Smith pump. Had to grind the block on my 440, ran out of room on the pump. What block do you have? I really do not want to grind my block
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: Brewzer67]
#2439728
01/23/18 09:09 PM
01/23/18 09:09 PM
davesmopars
cheshire, ct
Be ready to do some serious grinding on that Clay Smith pump. Had to grind the block on my 440, ran out of room on the pump. I hit it lucky and didn't have to clearance the block at all but it is a snug fit as it sits. I did have to clearance the pump almost to one of the screws. Last motor was a little over 600hp running with this pump and held a steady 7psi all the way down the track. Hopefully it will keep up with the new motor as well. Time will tell. What block do you have and do you run a return line?
[Re: sr4440]
#2439752
01/23/18 10:12 PM
01/23/18 10:12 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Ran the 110 Pump back when that was all you could get, for a while and it did drop in different locations on a pass. I also ran a very big line and big filter with no kinks and slow curves in the line up to the regulator that was beside the Carbs. Being a stick car with a violent leave I knew I needed more pump. I would spend the money on it once and buy a better pump. There are a lot of fuel pumps that do a much better job than the 110 Pump and are not that much more money. Usually a pump pushes better than it pulls so location of the type of pump you are using has an effect of performance of the pump. are you talking about a electric pump? Because a mechanical pump develops a significant amount of vacuum on the suction side(10 inches of mercury on a stock pump)unlike a electric pump. I have never tested a HP pump to see how much vacuum it pulls. To the OP, it's clear that the majority opinion is you need a very large pump. A 140 GPH pump from clay smith that, he claims, supports 1300HP might get you by. http://www.claysmithcams.com/mopar-b-426-chrysler-hemi/I give up. Joe from their website: And, according to Dyno figures, it takes approximately 10galllons of gas per 100 HP per hour, the Clay Smith Power Pumper will theoretically handle up to 1300 HP on gas or 1150 on alcohol ! "THEORETICALLY" Just like your signature says, Without Data, you’re just another guy with an opinion. I'd like to see that data that proves this will support 1300hp.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: davesmopars]
#2440048
01/24/18 03:10 PM
01/24/18 03:10 PM
davesmopars
cheshire, ct
Thanks everybody I called clay smith they recommend to run the pump with a regulator , check valve with a return line. I am running a cross ram with 4235 and 4236 carbs any suggestion on how I should set up my fuel system and lines. Thanks
[Re: davesmopars]
#2440068
01/24/18 03:40 PM
01/24/18 03:40 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Rigid 1/2" stainless feed lines, parker braided Teflon between the pickup and hard line and frame rail to the pump. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: davesmopars]
#2440366
01/25/18 02:18 AM
01/25/18 02:18 AM
Posts: 72 WI
Brewzer67
WI
Be ready to do some serious grinding on that Clay Smith pump. Had to grind the block on my 440, ran out of room on the pump. I hit it lucky and didn't have to clearance the block at all but it is a snug fit as it sits. I did have to clearance the pump almost to one of the screws. Last motor was a little over 600hp running with this pump and held a steady 7psi all the way down the track. Hopefully it will keep up with the new motor as well. Time will tell. What block do you have and do you run a return line? I would have to go down and look but I am pretty sure it is a '72 or '73 440 block.
[Re: davesmopars]
#2440420
01/25/18 06:12 AM
01/25/18 06:12 AM
Posts: 3,805 Arlington, Texas
bobby66
Arlington, Texas
Be ready to do some serious grinding on that Clay Smith pump. Had to grind the block on my 440, ran out of room on the pump. What block do you have? I really do not want to grind my block A '73 440. I mocked it up on a '78 400 and no grinding was needed on the block.
[Re: Cab_Burge]
#2440655
01/25/18 05:55 PM
01/25/18 05:55 PM
davesmopars
cheshire, ct
Hopefully the pump will fit. Picture not working, I need to take new one moparts uses old tech, I have to set my phone on old settings
[Re: davesmopars]
#2448498
02/08/18 01:53 PM
02/08/18 01:53 PM
davesmopars
cheshire, ct
Here is a picture on my block. Hopefully the pump fits. I have a solid roller cam. Is the stock fuel pump pushrod ok to use?
[Re: davesmopars]
#2448500
02/08/18 02:01 PM
02/08/18 02:01 PM
Posts: 13,360 Marion, South Carolina [><]
an8sec70cuda
No. You need a bronze tipped pushrod to use on a billet roller cam.
[Re: davesmopars]
#2448851
02/09/18 12:40 AM
02/09/18 12:40 AM
davesmopars
cheshire, ct
Any recommendations on who sells them?
[Re: davesmopars]
#2449194
02/09/18 07:20 PM
02/09/18 07:20 PM
davesmopars
cheshire, ct
Thanks Now how figure out the plumbing and the return line and make it look good.
