Re: Building a HP 440 with Factory Manifolds
[Re: bobby66]
#2440498
01/25/18 12:40 PM
01/25/18 12:40 PM
Posts: 4,405 Michigan
MarkZ
Worthy
Worthy
How do you guys get around the plug clearance problem with Edlebrock heads and HP manifolds? Don't the angled plugs get really close to the heat? You don't. I kept frying the #7 plug boot. It was my own stupid fault for buying Edelbrock heads. I knew there was better heads on the market with straight plugs. In the end this was my solution: Shorty headers as I didn't want the headache of long tubes. Decided to have them made out of stainless while I was at it.
[Re: Mr D21]
#2440507
01/25/18 01:02 PM
01/25/18 01:02 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Edelbrock E Street 84cc heads have straight plugs.
[Re: bobby66]
#2440544
01/25/18 02:05 PM
01/25/18 02:05 PM
Posts: 31,000 Oregon
AndyF
How do you guys get around the plug clearance problem with Edlebrock heads and HP manifolds? Don't the angled plugs get really close to the heat? I used the Mopar 452 heads (straight plug version of the Edelbrocks). There is a lot more clearance with the straight plug heads. Previously I had run the angle plug heads and had problems burning up one or two of the spark plug leads so I switched heads. What you really want from a clearance standpoint is an angle plug head on the driver side and a straight plug head on the pass side. That would work the best for the spark plug wires.
[Re: AndyF]
#2440557
01/25/18 02:34 PM
01/25/18 02:34 PM
Posts: 3,805 Arlington, Texas
bobby66
Arlington, Texas
How do you guys get around the plug clearance problem with Edlebrock heads and HP manifolds? Don't the angled plugs get really close to the heat? I used the Mopar 452 heads (straight plug version of the Edelbrocks). There is a lot more clearance with the straight plug heads. Previously I had run the angle plug heads and had problems burning up one or two of the spark plug leads so I switched heads. What you really want from a clearance standpoint is an angle plug head on the driver side and a straight plug head on the pass side. That would work the best for the spark plug wires. Interesting. Maybe I'll snag one 452 head for the passenger side.
[Re: Von]
#2440565
01/25/18 02:53 PM
01/25/18 02:53 PM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
Bsb...
I've always felt your combo is one of the most impressive combos on this board.👍👍 Thanks
[Re: Mr D21]
#2440734
01/25/18 09:47 PM
01/25/18 09:47 PM
Posts: 4,206 New York
polyspheric
New York
dogdays on point, as usual.
Shorties for street = excellent. Equal length highly over-rated for a engine with limited RPM and "warm" cam with moderate OL and wide LSA.
More trouble, more $$$, less efficient than shorties (but better than manifolds and very tight for clearance): fabrication from "weld ells".
Boffin Emeritus
[Re: fast68plymouth]
#2443190
01/30/18 01:51 AM
01/30/18 01:51 AM
Posts: 4,204 Fort Worth, TX
Clair_Davis
Fort Worth, TX
Edelbrock E Street 84cc heads have straight plugs. Are the 75cc heads angle-plug? The Edelbrock website shows angle plugs on the E-Street page, and I can't find any other pics of these heads on their website. Subscribed, as I'm building a HP manifold engine myself... Clair
[Re: AndyF]
#2443289
01/30/18 09:56 AM
01/30/18 09:56 AM
Posts: 287 PA
Harry's Taxi 2
PA
How do you guys get around the plug clearance problem with Edlebrock heads and HP manifolds? Don't the angled plugs get really close to the heat? I used the Mopar 452 heads (straight plug version of the Edelbrocks). There is a lot more clearance with the straight plug heads. Previously I had run the angle plug heads and had problems burning up one or two of the spark plug leads so I switched heads. What you really want from a clearance standpoint is an angle plug head on the driver side and a straight plug head on the pass side. That would work the best for the spark plug wires. Andy, a little off the topic, but where did you get those exhaust gaskets?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: Clair_Davis]
#2443560
01/30/18 06:10 PM
01/30/18 06:10 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Edelbrock E Street 84cc heads have straight plugs. Are the 75cc heads angle-plug? The Edelbrock website shows angle plugs on the E-Street page, and I can't find any other pics of these heads on their website. Subscribed, as I'm building a HP manifold engine myself... Clair Yes
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: Mr D21]
#2443585
01/30/18 06:54 PM
01/30/18 06:54 PM
bee1971
Sobieski Wi
Fel Pro MS90425 Exhaust Manifold Gaskets With Heat Shields
[Re: bee1971]
#2443595
01/30/18 07:06 PM
01/30/18 07:06 PM
Clair_Davis
Fort Worth, TX
Edelbrock E Street 84cc heads have straight plugs. Are the 75cc heads angle-plug? The Edelbrock website shows angle plugs on the E-Street page, and I can't find any other pics of these heads on their website. Subscribed, as I'm building a HP manifold engine myself... Clair Yes Ok, I didn’t ask that well- it looks like all the e-sreets are angle plug on the EB website, but some are clearly straight. Is the EB website wrong, and are the 84cc heads actually straight? Angle plugs don’t work with c-body hp’s and I need to go with straight plugs. Thanks, Clair
[Re: Mr D21]
#2443608
01/30/18 07:35 PM
01/30/18 07:35 PM
fast68plymouth
So. Burlington, Vt.
I don't know if the 84cc E Street heads were always straight plug, but they are now...... And there is a foot note in the catalog saying so. The 75cc version are still angled plugs.
#2443716
01/30/18 11:13 PM
01/30/18 11:13 PM
Clair_Davis
Fort Worth, TX
I don't know if the 84cc E Street heads were always straight plug, but they are now...... And there is a foot note in the catalog saying so. The 75cc version are still angled plugs. Perfect, thank you! Too bad EB doesn't have that note on their e-street page - kind of important, and was going to cost them a sale. I've been banking on using the Source Stealth heads on my stock-appearing build because they were about the only straight-plug option. The USA-made E-streets also flow a little better OOTB, too. Thanks again! Clair
[Re: Harry's Taxi 2]
#2445093
02/02/18 09:23 AM
02/02/18 09:23 AM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
How do you guys get around the plug clearance problem with Edlebrock heads and HP manifolds? Don't the angled plugs get really close to the heat? I used the Mopar 452 heads (straight plug version of the Edelbrocks). There is a lot more clearance with the straight plug heads. Previously I had run the angle plug heads and had problems burning up one or two of the spark plug leads so I switched heads. What you really want from a clearance standpoint is an angle plug head on the driver side and a straight plug head on the pass side. That would work the best for the spark plug wires. Andy, a little off the topic, but where did you get those exhaust gaskets? i know that ehrenberg sells those gaskets Is there another source ?
