Transmission lines
#2433214
01/12/18 02:55 AM
01/12/18 02:55 AM
Posts: 1,472 Martinsville, IN
cdwmotorsports
Martinsville, IN
I want to get away from the stock transmission lines on my Demon. Does anyone know what size fitting goes in the 727? Or if I can just screw an AN fitting on to the stock fittings?
eBay-cdwmotorsports
Re: Transmission lines
[Re: cdwmotorsports]
#2433233
01/12/18 04:24 AM
01/12/18 04:24 AM
Posts: 43,352 Bend,OR USA
Cab_Burge
They may be 1/4 NPT, do you have a 1/4 NPT tap to see with ?
#2433291
01/12/18 11:27 AM
01/12/18 11:27 AM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
Pretty sure they are 1/8" NPT. I use -6 AN also. Many will say to use the more expensive PTFE lined AN hose, but it isn't needed. It is better quality, but not required for trans lines.
#2433342
01/12/18 01:20 PM
01/12/18 01:20 PM
Posts: 4,213 New York
polyspheric
New York
Yes, use 3/8" line, don't want to slow down the cooling cycle. Put a B&M filter in the line somewhere before the cooler that you can service it to keep it clean (don't accumulate trash inside the cooler) and detect friction material loss.
Boffin Emeritus
#2433421
01/12/18 03:19 PM
01/12/18 03:19 PM
Posts: 3,113 Michigan
A727Tflite
Here is an image of one of those magnefine filters. Nothing wrong with the B & M except you have to cut then dispose of it each time you want to take a look. Plus it takes up a bunch of room. Flow is not an issue with the smaller filter but if you use one of these on a 1/2" line setup use the bug filter fittings. We did exhaustive test on these filters. And you Chrysler dealer techs will remember seeing these filters in our Reman trans kits. Those that used them ended the multiple trans failures when you followed the directions.
#2433449
01/12/18 03:47 PM
01/12/18 03:47 PM
Posts: 11,769 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
-6 Teflon. Yes, it's worth the little extra money. We've used some of the cooler with fan packages back under the car to eliminate some of the spaghetti at the front of the car. Has worked OK.
#2433513
01/12/18 05:36 PM
01/12/18 05:36 PM
Posts: 2,086 CA
crackedback
CA
-6 teflon/PTFE hose. I used some from this place. The only issue I had was the ends were not the standard sizes so the fancy AN wrenches didn't fit. Chinese stuff I'm sure and tolerances. Worked OK after that was figured out. http://anfittingsdirect.com/
#2433521
01/12/18 05:57 PM
01/12/18 05:57 PM
cdwmotorsports
Martinsville, IN
Since my car is outside and it’s snowed about 5” this AM does anyone have the ability to measure from the trans to in front of the radiator? I need to know line length so I can order this stuff. I’m using aeroquip startlite line and fittings.
eBay-cdwmotorsports
[Re: A727Tflite]
#2433543
01/12/18 06:51 PM
01/12/18 06:51 PM
Cab_Burge
The FWD cars used 5/16" line, most RWD cars in the day used 3/8" and so did most gas engine trucks, and we went to 1/2" lines on the 47/48 diesel for extra cooling of the lube.
All the early(1957 to 1974) Mopar V8 and leaning six cars automatic trans. cars I worked on, including the street hemi cars, had 5/16 O.D. lines on the tranny up to the radiator heaters ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I'm not sure what size lines my 2006 Ram 3500 4WD truck with the factory towing packages has for line I.D. or O.D. sizes ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) Maybe I should go check ![work work](/ubbthreads/images/graemlins/custom/work.gif) My first Dodge CTD Ram 2500 24 valve (1998 1/2) had the factory towing package on it, I added a tranny temp gauge and found out that it should have had a thermostat to the external tranny cooler, the trans temps never got above 140F when not towing, summer or winter in the CA Mojave desert ![work work](/ubbthreads/images/graemlins/custom/work.gif) I haven't added a gauge to this truck due to not wanting to worry about the trans temps
#2434356
01/14/18 12:38 PM
01/14/18 12:38 PM
cdwmotorsports
Martinsville, IN
Since my car is outside and it’s snowed about 5” this AM and it’s -9 does anyone have the ability to measure from the trans to in front of the radiator? I need to know line length so I can order this stuff. I’m using aeroquip startlite line and fittings.
eBay-cdwmotorsports
#2434713
01/14/18 11:41 PM
01/14/18 11:41 PM
Cab_Burge
What year and body style? The Plymouths have two inch longer wheel base so they may have different length lines also OOPS ![blush blush](/ubbthreads/images/graemlins/custom/blush.gif) I just reread the first post
#2435346
01/16/18 12:48 AM
01/16/18 12:48 AM
RapidRobert
I was thinking that someone priorly said that the ID somewhere in the internal cooling passages inside the trans makes going to a 3/8 line a moot point. If this is bogus I will for sure tap to the next larger size as those brass 1/8 NPT/inverted flare fittings are available in the next larger size along with useing 3/8 line.
