big block camshaft grind #2432569
01/11/18 12:37 AM
01/11/18 12:37 AM
Valencia, España
NachoRT74 Offline OP
Valencia, España
Some clue about these numbers on camshaft?
Re: big block camshaft grind [Re: NachoRT74] #2432575
01/11/18 12:44 AM
01/11/18 12:44 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
272 duration possibly,is the second number 11881? What engine does this fit?
Edit: I see big block!
Re: big block camshaft grind [Re: NachoRT74] #2432593
01/11/18 01:10 AM
01/11/18 01:10 AM
Valencia, España
Valencia, España
I haven't found anything with those numbers... yet
Re: big block camshaft grind [Re: NachoRT74] #2432602
01/11/18 01:25 AM
01/11/18 01:25 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Single bolt or three bolt timing gear?
Re: big block camshaft grind [Re: NachoRT74] #2432604
01/11/18 01:27 AM
01/11/18 01:27 AM
Valencia, España
Valencia, España
not mine... have not pic of the front... will ask
Re: big block camshaft grind [Re: NachoRT74] #2433075
01/11/18 10:14 PM
01/11/18 10:14 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Looks like a 9 under the last 2?
Re: big block camshaft grind [Re: 71GTX471] #2433162
01/12/18 01:12 AM
01/12/18 01:12 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Good eye!
Re: big block camshaft grind [Re: RTSrunner] #2433383
01/12/18 02:17 PM
01/12/18 02:17 PM
dogdays Offline
dogdays  Offline
One thing for sure, it isn't a Mopar Performance cam. I'm quite sure the "272" refers to advertised duration and MP/DC never named cams for their duration.
It most likely isn't an Isky cam because Isky usually had 270 degree cams, not 272.
So you're looking through all the old cam catalogs looking for cam families with a "9" or a "91" numbering prefix for B/RB engines.
R.
Re: big block camshaft grind [Re: 71GTX471] #2433488
01/12/18 04:48 PM
01/12/18 04:48 PM
Valencia, España
Valencia, España
you mean the 2 was stamped over a 9 ?
Re: big block camshaft grind [Re: dogdays] #2433491
01/12/18 04:50 PM
01/12/18 04:50 PM
Valencia, España
Valencia, España
R.
no, is not a purple... which in any case I think MP never got stamped? ( not on my 280/474 at least )
I'm really unsure where to search. Comp doesn't have ant duration rate like 272. I think neither Crower
Re: big block camshaft grind [Re: NachoRT74] #2433593
01/12/18 09:11 PM
01/12/18 09:11 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Try Crane
Leave the gun.......take the Cannoli's....Mike
Re: big block camshaft grind [Re: NachoRT74] #2433613
01/12/18 09:44 PM
01/12/18 09:44 PM
Valencia, España
Valencia, España
Crane barelly got 4 cams for Mopar Bb
Re: big block camshaft grind [Re: NachoRT74] #2433624
01/12/18 10:00 PM
01/12/18 10:00 PM
P
Porter67 Offline
Porter67  Offline
P
The pink and red paint marks tell me it started life as a mopar cam of some sort.
Re: big block camshaft grind [Re: NachoRT74] #2433675
01/13/18 12:07 AM
01/13/18 12:07 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
I pulled an old Crane cam, RV design, out of a 440 I bought years ago. It had 272 stamped on the end of it.
Re: big block camshaft grind [Re: NachoRT74] #2433678
01/13/18 12:12 AM
01/13/18 12:12 AM
E
elmor353 Offline
elmor353  Offline
E
Summit has 3 pages of Crane big block cams on their site.
Re: big block camshaft grind [Re: elmor353] #2433697
01/13/18 12:34 AM
01/13/18 12:34 AM
E
elmor353 Offline
elmor353  Offline
E
IIRC the Crane cam I pulled w/272 stamped on it was an Energizer series. I have been looking and the only Crane cam with 118881 comes up as a mech roller for small block chevy. Perhaps it's a very old part number.
Re: big block camshaft grind [Re: NachoRT74] #2433841
01/13/18 12:31 PM
01/13/18 12:31 PM
Valencia, España
Valencia, España
as mentioned it seems could be 911881 due a previous stamp to the last 2 of the 272
