big block camshaft grind
#2432569
01/11/18 12:37 AM
01/11/18 12:37 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
Some clue about these numbers on camshaft?
Re: big block camshaft grind
[Re: NachoRT74]
#2432575
01/11/18 12:44 AM
01/11/18 12:44 AM
Posts: 1,881 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
272 duration possibly,is the second number 11881? What engine does this fit? Edit: I see big block!
[Re: NachoRT74]
#2432593
01/11/18 01:10 AM
01/11/18 01:10 AM
NachoRT74
Valencia, España
I haven't found anything with those numbers... yet
[Re: NachoRT74]
#2432604
01/11/18 01:27 AM
01/11/18 01:27 AM
NachoRT74
Valencia, España
not mine... have not pic of the front... will ask
[Re: NachoRT74]
#2433075
01/11/18 10:14 PM
01/11/18 10:14 PM
Posts: 1,894 Harriman NY
71GTX471
Harriman NY
Looks like a 9 under the last 2?
[Re: 71GTX471]
#2433488
01/12/18 04:48 PM
01/12/18 04:48 PM
NachoRT74
Valencia, España
Looks like a 9 under the last 2? you mean the 2 was stamped over a 9 ?
[Re: dogdays]
#2433491
01/12/18 04:50 PM
01/12/18 04:50 PM
NachoRT74
Valencia, España
One thing for sure, it isn't a Mopar Performance cam. I'm quite sure the "272" refers to advertised duration and MP/DC never named cams for their duration.
It most likely isn't an Isky cam because Isky usually had 270 degree cams, not 272.
So you're looking through all the old cam catalogs looking for cam families with a "9" or a "91" numbering prefix for B/RB engines.
R. no, is not a purple... which in any case I think MP never got stamped? ( not on my 280/474 at least ) I'm really unsure where to search. Comp doesn't have ant duration rate like 272. I think neither Crower
[Re: NachoRT74]
#2433613
01/12/18 09:44 PM
01/12/18 09:44 PM
NachoRT74
Valencia, España
Crane barelly got 4 cams for Mopar Bb
[Re: NachoRT74]
#2433841
01/13/18 12:31 PM
01/13/18 12:31 PM
NachoRT74
Valencia, España
as mentioned it seems could be 911881 due a previous stamp to the last 2 of the 272
