Also, what are your engine specs...like crank, rods, cam, etc....?
30 over 360
Cast crank turned down 10 on mains and to chevy size 2.1 on rod throw.
6.25” chevy I beam eagle rods
Everything was balanced a couple weeks ago, took massive amounts out of counterbalance.
.480/.480 .230/240 115lsa blower cam
1.6 roller rockers should bring lift to .501ish
Main and head studs
.040 mls gasket
main girdle bought still need to machine main caps flat at work on mill
Heads.... And yes, I know the .100 lift #’s aren’t right. lol
And it’s going into this 3400# beast with 3.55 gears.
