Re: New Trick Flow heads for Ford FE
[Re: AndyF]
#2434528
01/14/18 04:51 PM
01/14/18 04:51 PM
Posts: 7,658 Minnesota
Hemi_Joel
Minnesota
Nice article Andy! I can't wait to see the dyno results. You didn't include FE Power in your list of sources.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: AndyF]
#2435341
01/15/18 11:39 PM
01/15/18 11:39 PM
Posts: 12 Minnesota
ThatDarnCat
Minnesota
Thanks, we should be on the dyno next week.
I usually only list the big parts in the source list. All I have from FE Power on this engine is the timing gear. Not a hard and fast rule, somewhat subjective but there is a space constraint in the magazine so typically just the big stuff gets listed. The big stuff is easy to find, it’s the unique parts that sometimes only have one source that people following the build usually need help finding. And a builder may find other parts they didn’t know existed and can use by visiting those specialty sites. JMO
[Re: ThatDarnCat]
#2436082
01/17/18 12:18 AM
01/17/18 12:18 AM
Hemi_Joel
Minnesota
I usually only list the big parts in the source list. All I have from FE Power on this engine is the timing gear. Not a hard and fast rule, somewhat subjective but there is a space constraint in the magazine so typically just the big stuff gets listed. The big stuff is easy to find, it’s the unique parts that sometimes only have one source that people following the build usually need help finding. And a builder may find other parts they didn’t know existed and can use by visiting those specialty sites. JMO Funny, I was thinking the same thing. .
[Re: AndyF]
#2441544
01/27/18 02:43 PM
01/27/18 02:43 PM
Posts: 31,344 Oregon
AndyF
[Re: AndyF]
#2441546
01/27/18 02:45 PM
01/27/18 02:45 PM
AndyF
[Re: AndyF]
#2441559
01/27/18 03:12 PM
01/27/18 03:12 PM
Posts: 44,242 Bend,OR USA
Cab_Burge
Where the wide ban readings accurate on that pull at WOT? What type of fuel?
[Re: AndyF]
#2441605
01/27/18 04:11 PM
01/27/18 04:11 PM
Posts: 8,278 Plymouth, MI
Blusmbl
Plymouth, MI
Awesome results, 700 hp from a relatively streetable n/a 482" motor is excellent. Plus it looks incredible with the period correct dual quad air cleaner on there!
[Re: Blusmbl]
#2441611
01/27/18 04:19 PM
01/27/18 04:19 PM
AndyF
Awesome results, 700 hp from a relatively streetable n/a 482" motor is excellent. Plus it looks incredible with the period correct dual quad air cleaner on there! We'll know just how streetable it is once we get the engine back in the car. Might need to go one size smaller on the cam. It is 254/260 solid roller which isn't huge for a 482 inch engine, but it still might be a little big for a Galaxie with 3.55 gears. Besides, I don't think the owner really needs 700 hp in that car! It is all stock, just a nice driver. Not a race car at all. Not even a hot street car, just a stocker.
[Re: AndyF]
#2442344
01/28/18 05:07 PM
01/28/18 05:07 PM
Posts: 9,039 fredericksburg,va
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
The interesting thing about FE engines is that there are a ton of different intake manifolds available. And the FE intake is super complex compared to the Mopar big block which makes it weird.
Basically the aftermarket has decided to tool up a bunch of really complex low volume intakes for the FE engine while they refuse to build simple intakes for the BB Mopar. Guess they just love the FE for some reason.........
We're using a tunnel wedge intake which is kind of a cool intake but there is nothing like that available for a BB Mopar engine. The tunnel wedge will be topped off with dual throttle bodies from FAST. The ignition is also from FAST and will all be controlled by the EFI system. How much money in this setup you have now? Too bad they don't look like a standard Holly, stealthy.
[Re: AndyF]
#2442355
01/28/18 05:24 PM
01/28/18 05:24 PM
AndyF
I think the parts list is around $20K at retail. The wildcard is the original standard bore 427 block. Those are super hard to find so that would be an expensive part to acquire.
Heads are $2500 EFI setup with computer, dual throttle bodies, ignition, etc. is $4000 Intake is $1000 Rotating assembly is $2500 Cam and lifters is $1000 Rocker arms and pushrods is $1500 Water pump, oil pan, damper, valve covers, air cleaner, etc. is $2000 Block is $2000+ Machine work, balancing, assembly, dyno labor, etc. is $2000 Dyno headers were $700 custom built Probably some other stuff I'm forgetting......
