cuda shaker brace weld questions #2425010
12/28/17 07:15 PM
12/28/17 07:15 PM
GA
roadrunninMark Offline OP
GA
Looking at doing the shaker hood conversion on a flat cuda hood and have some questions about welding on the underhood brace. Can anyone answer where are the locations for the spot welds? I don't have a spot welder so will have to plug weld it.
Also, does the trim ring cover the "cut edge" of the hood so it isn't seen or does the cut edge and brace sandwich it to the trim ring?
Can someone post pics of the underneath or even on an original hood? Also what it looks like from the trim ring through the "hole" and to where everything bolts together?
I know you can buy the AMD hood for 900, I am looking at a nice flat hood without any rust and was trying to save a few bucks.
Thank you
Re: cuda shaker brace weld questions [Re: roadrunninMark] #2425315
12/29/17 01:00 PM
12/29/17 01:00 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Best I know is the sheetmetal is sandwiched between the brace and the trim ring.
Re: cuda shaker brace weld questions [Re: roadrunninMark] #2425341
12/29/17 01:47 PM
12/29/17 01:47 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Scott Harms will know. He was involved in that kit.
Re: cuda shaker brace weld questions [Re: roadrunninMark] #2425542
12/29/17 09:35 PM
12/29/17 09:35 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
It depends on who's kit you are using
Re: cuda shaker brace weld questions [Re: roadrunninMark] #2425614
12/30/17 02:19 AM
12/30/17 02:19 AM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
Do you have the kit already? I have one I started on but did not finish.
Re: cuda shaker brace weld questions [Re: roadrunninMark] #2425785
12/30/17 02:01 PM
12/30/17 02:01 PM
GA
GA
Scott, I will PM you.
Magic, no kit yet, RestoRick's is sold out. Which do you have? Are you going to finish yours?
