Converting steering column
#2425517
12/29/17 08:20 PM
12/29/17 08:20 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
Taking an A/T from column shift to manual on the floor on a 72 Charger. Plan on ordering the column collars from Brewers but what is involved in getting the shifting mechanism off the steering column?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Converting steering column
[Re: dfsmopars]
#2425989
12/30/17 07:03 PM
12/30/17 07:03 PM
dfsmopars
Kentucky
What about getting the shifter arm and tube off the column? Major surgery?
[Re: dfsmopars]
#2426213
12/31/17 05:07 AM
12/31/17 05:07 AM
Posts: 10,951 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
There are a lot of parts. Spring loaded horn switch contact, key light, flasher switch, blinker switch, ignition switch, steering wheel locking assembly, three screws holding the top barrel on... It's all pretty straight forward until you get down to the steering wheel lock gear and the little C ring that holds the lower barrel on at the bearing. I always take photos during disassembly. I believe there will be a roll pin in the shift selector arm. A factory service manual will help and is recommended. That C ring is a bear. A nice sharp hooked probe is handy to get it off without boogering things up. Actually I am thinking there are two. One for the gear and one for the cylinder.
I’m listening.
[Re: dfsmopars]
#2426239
12/31/17 11:04 AM
12/31/17 11:04 AM
dfsmopars
Kentucky
Thanks. That sounds about like I was expecting. I do have a manual that has an exploded view and some steps but I think it has to be too abbreviated. I’m down to pulling the splined retainer which is very solid. Letting it soak a little then try again.
