SFT cam valve adjustment question #2424852
12/28/17 01:21 PM
12/28/17 01:21 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
This has been discussed many, many times, but, here goes again..
I have tried all the different ways to adjust valves. For the past several years I have been doing one cylinder at a time and rotating the engine to put a valve at max lift( whether it be intake or exhaust), to adjust the other valve for that cylinder. Where am I going wrong????
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: SFT cam valve adjustment question [Re: 68LAR] #2424861
12/28/17 01:37 PM
12/28/17 01:37 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Get a remote start or make one if ya don't have one first thing, then bump engine over til exhaust just starts to open, adjust intake valve on that cylinder. bump again til intake is almost closed, then adjust exhaust on that cylinder. Once done a couple times, you will run right thru them within 15-20 mins.
Re: SFT cam valve adjustment question [Re: 68LAR] #2424888
12/28/17 02:22 PM
12/28/17 02:22 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
iagree
Ditto!
Re: SFT cam valve adjustment question [Re: 68LAR] #2424938
12/28/17 03:53 PM
12/28/17 03:53 PM
Cab_Burge Online work
Cab_Burge  Online Work
You can do it the way suggested on race cams, on milder cams you can bring each piston up to TDC on the firing stroke and adjust both valves then shruggy
Or do it the old school way of adjusting one valve at a time with the motor running, which is a real beast to do and nasty from all the oil spilling all over the motor and engine compartment down
Re: SFT cam valve adjustment question [Re: 68LAR] #2425107
12/28/17 10:52 PM
12/28/17 10:52 PM
gregsdart Offline
gregsdart  Offline
I went to the trouble of measuring lash at ten degree intervals just to see how much they changed from each position. On a roller cam with 340 on the seat for preasure, they varied .004 to .0045. So with a mild sft cam with only 150 or less on the seat and much less over the nose i would guess the flex would be .002 or less, not enough to worry about. IMHO the one thing that can be gained by very accurate positioning for setting each valve is to find any problems early on.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: SFT cam valve adjustment question [Re: gregsdart] #2425279
12/29/17 11:52 AM
12/29/17 11:52 AM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Ok, thanks for the replies. But just for kicks, why is the way I've been doing it not as good as suggested? Why is one way better than the other. Not trashing any suggestion, just curious why one way is better than the other? My cam, by the way is a smaller SFT. 259*/266* tight lash .014"/.018" .633/.627" with 1.6 rockers.
Re: SFT cam valve adjustment question [Re: 68LAR] #2425308
12/29/17 12:45 PM
12/29/17 12:45 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
You have to make sure the lifter is on the base circle of the lobe. New lobe designs make it a little more difficult to find that point. I do the exhaust just opening, intake almost closed method and never have an issue. As stated above, once you do it a few times it becomes second nature.
Re: SFT cam valve adjustment question [Re: fbs63] #2425489
12/29/17 07:33 PM
12/29/17 07:33 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Same here. When I checked my newest cam, the lobe closed -0.001 below the base circle, then returned to the base circle setting. If setting exhaust at max intake, it might be in that range?, but at base circle at intake closing.
Re: SFT cam valve adjustment question [Re: 451Mopar] #2425507
12/29/17 07:50 PM
12/29/17 07:50 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
I understand the base circle thing. Where I have a question is the replies. When adjusting the intake. Do it when the exhaust is just opening. I guess you have to monitor so there just begins to have "zero" gap. Same for doing the exhaust. Adjust when intake is just closing??? Seems to be not so precise or exact to me. Maybe I'm reading too much into this. Also, will .001" make that big a difference in performance? I'm not trying to be a pain in the butt, just trying to clarify things. in my semi-empty head.. Thanks for understanding.
Re: SFT cam valve adjustment question [Re: 68LAR] #2425512
12/29/17 08:08 PM
12/29/17 08:08 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The 0.001 really is not a big deal for me, depends on how tight you adjust the valve lash, because 0.001" at the cam is multiplied by rocker ratio, so in my case 1.6:1 rocker, 0.0016" difference in valve lash?
Re: SFT cam valve adjustment question [Re: 68LAR] #2425892
12/30/17 04:08 PM
12/30/17 04:08 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Don't worry about that, it's a good topic for discussion even if it's been covered before. I used to adjust at TDC compression and after someone posted in one of these threads that lobe ramps could have an effect at that point I went to the exhaust opening/intake almost closed method. The last time I remember this topic coming up more than one said to use the TDC method. It so happened that at that time I had a shortblock with a long-duration (~320º) solid/flat cam on the stand all set up for checking. I checked it out and there was absolutely no lobe ramp detectable near TDC compression so I might go back to that method. That puts both valves on the seat when checking and should produce consistent results.
twocents
Re: SFT cam valve adjustment question [Re: @#$%&*!] #2426103
12/30/17 11:16 PM
12/30/17 11:16 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Interesting, very interesting....
Re: SFT cam valve adjustment question [Re: mopar dave] #2426678
12/31/17 08:55 PM
12/31/17 08:55 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
As stated, when done this way with the remote starter switch, it’s pretty quick.
Re: SFT cam valve adjustment question [Re: 68LAR] #2426681
12/31/17 09:06 PM
12/31/17 09:06 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I use the 180* method with a remote start trigger. Takes me about 3/4 of a beer. Once a year, and after 7 years with this motor I’m yet to find anything alarming.
Re: SFT cam valve adjustment question [Re: StealthWedge67] #2427226
01/01/18 04:51 PM
01/01/18 04:51 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Care to explain? The 180* method, that is, I got got the beer part!
Re: SFT cam valve adjustment question [Re: 68LAR] #2427254
01/01/18 05:29 PM
01/01/18 05:29 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Larry, It really pays to learn the EOIC method, exhaust open intake closes, as I think some have already mentioned.
I have a starter button on my firewall. I bump the starter button, as soon as the exhaust rocker starts to move(nose of rocker moves down) I check the intake rocker lash.
Bump starter until intake rocker arm nose goes all the way down and bump again til it starts to move upward, set exhaust rocker lash.
I've tested this method against the MP 180 degree method and the lash was the same. It may not work for every single cam but I don't know why it wouldn't. I do this on my purpleshaft solid cams and I did it this way on my 700 lift roller in my '69 Dart.
This is a very quick and easy method of checking lash.
Re: SFT cam valve adjustment question [Re: 68LAR] #2427259
01/01/18 05:37 PM
01/01/18 05:37 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I also like to set a small level on my valve cover and jack up the rear of the car until the valve cover is level. Now I can remove my valve covers without oil dripping out of the rear of the heads.
And if you have a decent set of feeler gauges, you can literally leave the feeler gauge under the rocker arm while bumping the motor over, it will give you a good feel for what the cam lobe is doing.
Re: SFT cam valve adjustment question [Re: ProSport] #2427452
01/01/18 10:56 PM
01/01/18 10:56 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Thanks Bob, I do have a remote starter switch. I'm going to try the EOIC method and compare it to the way I have been doing it. Thanks everyone for the input. I appreciate it. ( that level idea is something I never thought of). I'll try that also....
Re: SFT cam valve adjustment question [Re: 68LAR] #2427457
01/01/18 11:08 PM
01/01/18 11:08 PM
Puyallup, WA
Puyallup, WA
Re: SFT cam valve adjustment question [Re: 68LAR] #2427499
01/02/18 12:26 AM
01/02/18 12:26 AM
A727Tflite Offline
A727Tflite  Offline
The "180" method is called out in the Chrysler service manuals for the 426 hemi lash adjustment procedure.
