Re: Looking to 2018. What are you Building?
[Re: Porter67]
#2424688
12/27/17 11:46 PM
12/27/17 11:46 PM
Posts: 1,101 Massillon, Ohio
cudatom
Massillon, Ohio
The Cuda gets a new cage in Feb to replace the one installed in 1988. Still trying to decide on a power plant. Leaning towards a 540 w/a F2 or a 540 w/B1's. This will probably be a 2018-2019 build. Lol
Ok
[Re: Dragula]
#2424694
12/27/17 11:53 PM
12/27/17 11:53 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I have a set of G3 ported Eddy heads, and I just scored a mint 400 block, and a set of new Hedman fenderwll headers, and I am just finishing the install of my 605 Hemi in the Cuda.... Those pieces should fit together nicely
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Porter67]
#2424701
12/28/17 12:10 AM
12/28/17 12:10 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Remove my 547 wedge from my sons car, remove the heads and put them onto his 440 and fit it to his car. Refresh the 547 short. Remove my 528 wedge from the Cuda, remove the heads and give them a rebuild with new springs and locks. Fit the heads to the 547 and fit into the Cuda with new convertor. Refresh 528 and wrap it up. Fabricate molly cage for the Cuda.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: Porter67]
#2424790
12/28/17 07:44 AM
12/28/17 07:44 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Hopefully a 50x80x16 pole barn in the back yard to put everything in, with a lift!
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Porter67]
#2424809
12/28/17 11:33 AM
12/28/17 11:33 AM
Posts: 3,443 Northern N.J.
hemi_doug
Northern N.J.
65 Plymouth Satellite to do some bracket racing with. 506 wedge with Victor maxwedge and solid roller.Shooting for 10.0s The chassis is being done now. Plan is a narrowed Dana with Caltracs and mono springs. Once that is completed and ready it's on to the driveline. Hope to have it ready for shakedown passes this year and turn my daughter loose in it at some point. She has some time left to Jr. race so we aren't in a hurry.
71 440-6 4spd & 69 Hemi 4spd
[Re: hemi_doug]
#2424824
12/28/17 12:26 PM
12/28/17 12:26 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Buy new axles, weld in subframe connectors and a cage and do some footbrake bracket racing w/ this car.
[Re: an8sec70cuda]
#2424825
12/28/17 12:27 PM
12/28/17 12:27 PM
an8sec70cuda
Finish reassembling this '71 Demon 340 and ruin some tires.
[Re: Porter67]
#2424887
12/28/17 02:21 PM
12/28/17 02:21 PM
Posts: 2,533 Alexandria, LA
Blucuda413
Alexandria, LA
Plan to have my renewed 68 Cuda back out early in the year. Over the past 2 yrs I have almost completely redone the whole car. I started with replacing the 8 3/4 and suspension with an aftermarket 9", new aluminum driveshaft, new suspension and a new set of slicks. I also removed all of the stock front suspension and built new K member setup for installation of Lamb struts, Pinto rack & pinion steering and Centerline spindle mount wheels. The power plant is my NA 413ci Xblock converted to a basically new blower motor. Using the Xblock and my 3.91 crank I have new Large Port Commando heads, new Racetec pistons on Lentz rods. Intake is a Offenhauser blower manifold with a 6-71 sitting on it. For fuel delivery I have a Hilborn bugcatcher injection which I have set up for E85. Didn't do anything to the JW Powerglide trans except change it's location a little over an inch.
One of the biggest challenges was determining location and designing mounts for hilborn fuel pump, vacuum pump, alternator and the CSI electric water pump. I had it all mocked up and then decided to go to the strut front end which required use of a motor plate. That required redo of all the mounting plans for the front of the engine. I've got it all figured out now and should be ready in Feb or March.
[Re: Porter67]
#2424899
12/28/17 02:30 PM
12/28/17 02:30 PM
Triple Threat
Renton Washington
I bought a 68 Barracuda F/SA Stock Eliminator car that has been sitting for a decade. Been going through it, cleaning it up, all new wiring, new fuel system, carpet, seats, painting etc. I will run it some this year with a 360/380 crate motor while going through and building a 340 for it to be run in stock again. Day 1 Removed the old stickers Trunk 360/380 crate motor with a few upgrades. Repainted engine bay
[Re: Porter67]
#2424923
12/28/17 03:06 PM
12/28/17 03:06 PM
Posts: 11,713 Portage,michigan
B3422W5
Portage,michigan
Gary..... you coming to Norwalk this coming year?
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2424927
12/28/17 03:14 PM
12/28/17 03:14 PM
Posts: 803 Idabel,Oklahoma
Gary Robbins
Idabel,Oklahoma
Gary..... you coming to Norwalk this coming year? Doubtful as it's the same weekend as the Polaris dealer show and someone from the store needs to be there which is usually me !! I love the MMW show and people but hate the date change !!
[Re: Porter67]
#2424930
12/28/17 03:27 PM
12/28/17 03:27 PM
Posts: 860 lancaster,california
johnnycuda
I'm hoping to take the Cuda out a few times this year, considring adding a 150 shot to it, that's why I'm pondering ordering a Dana to repalce the 8.75. I'm just finishing my '69 Valiant sleeper, should be fun to drive, plan to drive it to the track, should go high 11's/low 12's on the motor.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: Gary Robbins]
#2424944
12/28/17 04:04 PM
12/28/17 04:04 PM
Posts: 883 Affton MO
qwkmopardan
Affton MO
Put my new PSO headed B1 in Silverfish and hopefully run some 4.50-4.70'S according to class and jet limit !! Better get rid of that JW wheel. The one I had in my Lebaron shed the starter ring and nearly sawed the passenger side frame rail in two. The "Wheel" was only a couple years old as well.
[Re: theraif]
#2425037
12/28/17 07:59 PM
12/28/17 07:59 PM
Posts: 20,179 PA.
pittsburghracer
"Little"John
"Little"John
PA.
going to try to make mad money selling art heheheh That will work as ALL Artist are rich. LOL. I'm still paying off my Sons Art School loan. Ohhhh and he's a Parts Manager at an Autobody shop in Colorado so that counts, RIGHT!!!!!
