Re: 4150 or 4500 carb??
[Re: DblOJoe]
#2423200
12/24/17 06:29 PM
12/24/17 06:29 PM
Thumperdart
State of confusion
Thinking about trying a 4500 but would like some opinions here's my combo.
446Ci 440 10.5 compression Trick Flow 240 heads 267@ .050 solid flat tappet. Victor Intake and a 80496-1 950 hp that's had some work done by Thumper. Runs on 93 pump gas. The rest of the car is 8" 5800 converter 4.10 Dana (Originally was 4.30 8 3/4 but it broke) Car weighs 3470 now with me and last time out in pretty good air it went 10.39 @ 127 The 950 runs great and has awesome shift recovery so that and the car weight has me skeptical. Thoughts??? Do you have room for a 2" adapter...........
[Re: DblOJoe]
#2423290
12/24/17 09:32 PM
12/24/17 09:32 PM
Posts: 43,237 Bend,OR USA
Cab_Burge
[Re: DblOJoe]
#2423314
12/24/17 10:04 PM
12/24/17 10:04 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
Sounds like a ton of convertor.5800 flash?
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: DblOJoe]
#2423970
12/26/17 05:30 PM
12/26/17 05:30 PM
crabman173
crabman173
Drag only they usually really like a dominator--get the 2 inch adapter --smooth around in there no big deal and I bet you will likey!!
