Looking for advise on 413 head swap 65 crew cab Power wagon! #2422540
12/23/17 01:33 AM
12/23/17 01:33 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
I am buying this 65 crew cab. Its originaly a 318 rig. Been sitting since 1992. Has a swappedcout 413. Im thinking 440 top end like 906 heads new water pump intake carb and Maybe C body HP manifolds. ?
Im also looking to change it to power steering. Want to build an around town driver. I live in the hills.
Opinions?
Thx Dave.
Re: Looking for advise on 413 head swap 65 crew cab Power wagon! [Re: RUMBLON] #2422541
12/23/17 01:35 AM
12/23/17 01:35 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Some pics
Re: Looking for advise on 413 head swap 65 crew cab Power wagon! [Re: RUMBLON] #2422565
12/23/17 03:05 AM
12/23/17 03:05 AM
Guitar Jones Offline
I love it. The top end swap shouldn't be too bad. The power steering will certainly be something else though. Good luck with that.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Looking for advise on 413 head swap 65 crew cab Power wagon! [Re: RUMBLON] #2422638
12/23/17 01:30 PM
12/23/17 01:30 PM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
Sounds like way too much work involved. Don't bother with it & sell it...to me! grin
Looks like a good solid truck & will be really cool truck when it up & running.
Re: Looking for advise on 413 head swap 65 crew cab Power wagon! [Re: RUMBLON] #2422716
12/23/17 05:31 PM
12/23/17 05:31 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Looks like a "Truck/Industrial" motor (as in not passenger car/PU)Im not certain but I don't think its as easy as a upper end change over...
Ramchargercentrail
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Looking for advise on 413 head swap 65 crew cab Power wagon! [Re: W.I.N. Racing] #2422886
12/23/17 11:27 PM
12/23/17 11:27 PM
Canada
Chris Johnson Offline
Canada
Ramchargercentrail
For sure it is a truck/industrial 413. I have one that I rebuilt .030" over and put it in a Dakota with the industrial heads and all. I too want to eventually swap over to 452 or 906 heads, but haven't had the time. The 413's are still just an RB block so "normal" heads and water pumps will mount to them. Just be aware that these are low compression motors with dish pistons so putting on 906 heads will lower your compression ratio, that way I wanted to go 452 closed chamber heads to help offset that.
My 413:
Re: Looking for advise on 413 head swap 65 crew cab Power wagon! [Re: RUMBLON] #2423106
12/24/17 02:56 PM
12/24/17 02:56 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
452 heads might work better for what you want. Same ports as 906's, but if I remember right....they have hardened valve seats. The PS might be the harder issue to remedy. I had a 70 model D200 2wd truck, that had PS. The steering box was about as big as your fist, and it had this thing that looked like a shock with 10 PS lines hood to the drag link. I don't know if 4wd trucks have the same setup or not? shruggy The PS was the only reason I sold that truck. It leaked like a sieve, and had about a half a round of slack....and I couldn't find any parts to fix it. Looks like a nice old more door truck to fix up....so good luck! up
Re: Looking for advise on 413 head swap 65 crew cab Power wagon! [Re: RUMBLON] #2423215
12/24/17 07:03 PM
12/24/17 07:03 PM
east side of Ohio
basketcase Online content
basketcase  Online Content
east side of Ohio
great truck!
1981 Dodge D150 360 auto
Re: Looking for advise on 413 head swap 65 crew cab Power wagon! [Re: Chris Johnson] #2423834
12/26/17 05:00 AM
12/26/17 05:00 AM
Not trying to hijack this thread but I'm putting a 440 motor together for customer who will install it in a 1972/76 era W200 4x4 that ended up with a rear sump truck or Class a motor home oil pan with the external dipstick tube and dipstick and I don't have any idea what the oil capacity is, can any of you help me on this help
Thanks in advance up
OP, that motor is NOT out of Imperial, it is a truck, motor home or industrial 413 motor thumbs
I'm starting to put one of those motors using block and crankshaft only with the crankshaft offset ground down to 2.200 and increasing the stroke to 3.91 up
It's getting hot tanked and magnafluxed now and if it passes and has no cracks I will have it bored to 4.250 and make a pump gas motor with a set of 440 Source aluminum heads on it for my 1963 Plymouth Fury boogie
Re: Looking for advise on 413 head swap 65 crew cab Power wagon! [Re: RUMBLON] #2423892
12/26/17 01:56 PM
12/26/17 01:56 PM
OH
Red383 Offline
Red383  Offline
OH
I'd get it running the way it is, and drive it. That's where I am going to start on my 65. If it's just going to be an around town driver, that 413 should do just fine to start. You can always upgrade it later.
Re: Looking for advise on 413 head swap 65 crew cab Power wagon! [Re: RUMBLON] #2424148
12/26/17 10:57 PM
12/26/17 10:57 PM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
There was a great article about adding power steering to a power wagon years ago in the power wagon advertiser.
If you need that info for reference please pm me
Red
Re: Looking for advise on 413 head swap 65 crew cab Power wagon! [Re: Cab_Burge] #2424327
12/27/17 12:23 PM
12/27/17 12:23 PM
Palm Coast, FL (near Daytona B...
Blown_Hemi Offline
Blown_Hemi  Offline
Should be a 6 quart pan. Here is what I did when I needed to install the bung for the external dipstick on my Milodon 8 quart pan. Filled pan with 8 quarts of water and measured the water level from pan rail, marked dip stick tube at the full level and marked where bung needed to be welded in.
Ask me my opinion of Frank Mitchell....... A Mopar crook!
Re: Looking for advise on 413 head swap 65 crew cab Power wagon! [Re: Blown_Hemi] #2424462
12/27/17 04:18 PM
12/27/17 04:18 PM
I'm not sure if this pan is a 440 motor home pan or a 413 truck pan confused
I called one of the local auto repair shops that has a on line subscription to either Mitchells or motor manual information, he found that the 440 motor home pan hold 6 quarts and the 413 motor homes and trucks hold 8 quarts work
Thanks for your help up
Re: Looking for advise on 413 head swap 65 crew cab Power wagon! [Re: RUMBLON] #2437502
01/19/18 03:13 PM
01/19/18 03:13 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Thx for the advise
