Re: Harbor Freight Engine Cherry Picker / Lifting an Engine
[Re: MuuMuu101]
#2423022
12/24/17 10:13 AM
12/24/17 10:13 AM
Posts: 21,066 in a cattle trailer down by th...
Guitar Jones
First, did you try it to see if it works? I've never had to add oil to any cylinder either.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: MuuMuu101]
#2423023
12/24/17 10:15 AM
12/24/17 10:15 AM
Guitar Jones
I'm not sure the cherry picker I have has had that plug for the last 5 years. A wrap around the ram with electrical tape and it's good to go. I like the way you think. Duct tape!
[Re: MuuMuu101]
#2423086
12/24/17 02:13 PM
12/24/17 02:13 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I never had to ad oil to my cherry picker but to bottle jacks. The rubber plugs are difficult to get in but I have used a small screw driver to work it in. I have also lost the rubber plug upon removal , bing and it was gone forever. The duct tap method was used and has been on for years.
[Re: MuuMuu101]
#2425266
12/29/17 10:21 AM
12/29/17 10:21 AM
Posts: 2,137 Byron, NY
W.I.N. Racing
Byron, NY
OMG...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Guitar Jones]
#2425362
12/29/17 02:36 PM
12/29/17 02:36 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
First, did you try it to see if it works? I've never had to add oil to any cylinder either. Yes I did! Because of that I ended up reading the instructions which states, "Hyrdaulic Oil Not Included."
[Re: mopars4ever]
#2425367
12/29/17 02:41 PM
12/29/17 02:41 PM
Posts: 20,273 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Its really not that hard guys. A little lube and push it in.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: mopars4ever]
#2425370
12/29/17 02:48 PM
12/29/17 02:48 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Did the instructions say how to remove and install the rubber plug? LOL The instructions didn't even refer that the plug was the fill hole.
