stuck wrist pins
#2420593
12/18/17 08:49 PM
12/18/17 08:49 PM
RapidRobert
Sealed Power h405 new pistons. eBay purchase. pins are stuck & I soaked one of em in the solvent tank for a day or so & still stuck. should I tap it with something or soak it in something else? thank you for your time.
Re: stuck wrist pins
[Re: stumpy]
#2420604
12/18/17 09:07 PM
12/18/17 09:07 PM
RapidRobert
Will do. EDIT how hot? MORE EDIT Stump you're the man! it took the oven several minutes to get up to 300 & I took it out to check it after several minutes as I dont want to damage it & to my surprise it came out, so I stuck the rest of em (ex for the one still in the solvent tank) in there. EVEN MORE EDIT Done! (7 of em) alum sure must expand way faster (or a greater amt) than steel. That was WAY too easy.
[Re: RapidRobert]
#2420778
12/19/17 02:24 AM
12/19/17 02:24 AM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Will do. EDIT how hot? MORE EDIT Stump you're the man! it took the oven several minutes to get up to 300 & I took it out to check it after several minutes as I dont want to damage it & to my surprise it came out, so I stuck the rest of em (ex for the one still in the solvent tank) in there. EVEN MORE EDIT Done! (7 of em) alum sure must expand way faster (or a greater amt) than steel. That was WAY too easy. Actually both. :-)
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: Cab_Burge]
#2420812
12/19/17 03:44 AM
12/19/17 03:44 AM
RapidRobert
Rallye I will do. Cab yes it was no time at all in there (I was worried that 300 was to hot) so I pulled the one out fairly quick & it was free.
[Re: RapidRobert]
#2420862
12/19/17 11:13 AM
12/19/17 11:13 AM
Posts: 3,547 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Will do. EDIT how hot? MORE EDIT Stump you're the man! it took the oven several minutes to get up to 300 & I took it out to check it after several minutes as I dont want to damage it & to my surprise it came out, so I stuck the rest of em (ex for the one still in the solvent tank) in there. EVEN MORE EDIT Done! (7 of em) alum sure must expand way faster (or a greater amt) than steel. That was WAY too easy. You can actually expand a piston by holding it in your hands too much and warming it up! I found that out about 40 years ago working on snowmobile engines. You can also " compress" a piston with your hands when measuring if you squeeze it hard.If you put a 4" mic on a piston skirt, squeeze it with your hand, the mic will fall right off...
RIP Monte Smith
[Re: CompWedgeEngines]
#2420865
12/19/17 11:34 AM
12/19/17 11:34 AM
RapidRobert
Alright let me do this, I will clean the remaining piston that is resting in the solvent tank & warm it up with my hands & see what transpires. The ladies' say my hands are magic so lets see if that works across the board
[Re: moparx]
#2420923
12/19/17 01:59 PM
12/19/17 01:59 PM
RapidRobert
Understood, I'm always on my best behavior.
[Re: moparx]
#2420965
12/19/17 03:29 PM
12/19/17 03:29 PM
Posts: 43,744 Bend,OR USA
Cab_Burge
[Re: RapidRobert]
#2420968
12/19/17 03:36 PM
12/19/17 03:36 PM
Porter67
[Re: dogdays]
#2421114
12/19/17 08:51 PM
12/19/17 08:51 PM
RapidRobert
I haven't ever heard of needing 300 degrees F to get the pin to slide out. Usually, hot water from the tap is all that's necessary. R. Yes I was worried that I set it too high & luckily I went back in the oven pretty quick. Dog what I am gonna do is put my healing hands on it & see if that does the trick (it usually does!) then if not then hot water then the oven again at maybe 150.
[Re: RapidRobert]
#2421382
12/20/17 12:04 PM
12/20/17 12:04 PM
RapidRobert
I just put my healing hands on it & in short order it came right out (I couldn't believe it). thanks guys!
