Re: Some old iron
[Re: fast68plymouth]
#2420811
12/19/17 03:41 AM
12/19/17 03:41 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Duane. That's some very nice work you've done with those. How do you tell if a head has core shift? Do you look at the chambers and the positioning of the valve cuts? Ivenoticed on different sets of heads that some shrouding is different from one chamber to the other. Is that how you tell? Thanks
Re: Some old iron
[Re: Lee446]
#2420847
12/19/17 09:58 AM
12/19/17 09:58 AM
Posts: 8,680 Buford, GA
I_bleed_MOPAR
Buford, GA
At over 600 views, I think you underestimated your audience! Lots of us want to learn what it takes to work your magic. Very interesting post! Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: Some old iron
[Re: I_bleed_MOPAR]
#2420861
12/19/17 11:08 AM
12/19/17 11:08 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
[quote=Lee446]At over 600 views, I think you underestimated your audience! Lots of us want to learn what it takes to work your magic. Very interesting post! I think everyone would be shocked at the amount of "still" stockish engines and heads people request work on..., because this crew mostly hangs here on the Race site, its not always visible, how many regular old iron heads are still in service, and servicable for that matter....boats street drivers, even some industrial stuff.....I see it in all brands still, with the BBF guys still loving the big iron 460 heads.There is still a demand for some iron.Dwaynes work top notch as usual.
RIP Monte Smith
Re: Some old iron
#2453099
02/17/18 04:50 PM
02/17/18 04:50 PM
Posts: 494 IL
EchoSixMike
IL
Since this is a cool thread, I thought I'd bring it back up with a set of old iron I'm puttering with. These are some old 906's I'm going to try to resurrect. First job is installing step guides for the smaller stem valves. I'm waiting on valves, so I'm just doing spring pads and guide install for now, I'll do the VJ when I get the valves in. 5/16 intakes and 11/32 exhausts. Yes, the heads are still scuzzzy, that's by design, going into a bit of a sleeper setup. S/F....Ken M
Last edited by EchoSixMike; 02/17/18 07:38 PM. Reason: I give up on fixing the photo order, it's obvious which comes first, etc
