Dry sump vs wet: School me
#2420013
12/17/17 08:56 PM
12/17/17 08:56 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
Haven't been here for awhile. Yet another new project in the works now.
I picked up a 500" KB Mopar aluminum block with original B1 heads. I'll have to rework some things from the previous use as a roundy-round motor. Originally was set up as with a dry sump oiling system and still has the oil pan. No pump, mount, drive system etc.
Converting this to a drag racing setup for a 70 Duster. Looks like I could go external wet or dry sump. I get the advantages of less oil in the motor with a dry sump, but is the benefit worth the potential $4k investment? Being an aftermarket block, I don't see any provisions for internal oiling which is fine. Shooting for 10.0 up here on the hill.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
Re: Dry sump vs wet: School me
[Re: herkamer]
#2420024
12/17/17 09:20 PM
12/17/17 09:20 PM
Posts: 2,094 Byron, NY
W.I.N. Racing
Byron, NY
As a bracket racer no benefit. As a corner turner it was useful to control oil slosh in the turns. A proper baffled pan and an external pickup and your all set.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: herkamer]
#2420121
12/18/17 01:05 AM
12/18/17 01:05 AM
herkamer
Lakewood, Colorado
Looking at how the pan is configured, everything is on the right side so I would have to probably add some fittings anyway. Not sure if having the kickout on the right side would make much difference if there was 2 outlets on the back.
What all is involved in designing a system that works? Looks to be confusing as to how many stages etc.
[Re: herkamer]
#2420125
12/18/17 01:12 AM
12/18/17 01:12 AM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
IMO for a bracket car it is NOT worth the expense in a Mopar block design. If you are looking every last little HP then its worth looking at. Otherwise the extra expense is better used elsewhere.
[Re: herkamer]
#2420143
12/18/17 01:30 AM
12/18/17 01:30 AM
herkamer
Lakewood, Colorado
I don't think it would make enough of a HP difference for my goal. I figure if I ever want to change it later, I can add some boost to it.
Motor came from Ohio. Some dirt track car I guess.
[Re: herkamer]
#2420182
12/18/17 02:18 AM
12/18/17 02:18 AM
Posts: 4,205 New York
polyspheric
New York
A wet sump is close if the pan is deep enough that the crank is well above any oil level including high G and high negative G. Really de-aerating oil requires a tall vertical tank, air comes out of suspension as it passes through. By comparison, a wet sump may only be a few inches deep and returned oil may reach the pickup in seconds, unless the pan is very baffled to form a labyrinth.
Boffin Emeritus
[Re: herkamer]
#2420319
12/18/17 02:00 PM
12/18/17 02:00 PM
Posts: 2,603 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I think the main reason for running a dry sump for people like us is they look sexy. To me a lot of the fun of working on these cars is the beautiful parts we have to work with.
2011 Drag Pak Challenger
[Re: herkamer]
#2420426
12/18/17 05:15 PM
12/18/17 05:15 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I only wish I could afford a dry sump pan for my Hemi, because if I could afford the dry sump, I could afford to finish my car...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
