Re: Chapman Stage VI 260 questions
[Re: dbran451]
#242017
03/06/09 10:37 PM
03/06/09 10:37 PM
Posts: 8,182 Detroit, MI
CokeBottleKid
Detroit, MI
do these heads use the RB intake on a B motor like the orignal sixes
Yes they do.
[Re: JohnRR]
#242018
03/17/09 08:23 PM
03/17/09 08:23 PM
Posts: 75,134 A Banana Republic near you.
JohnRR
... the your current head stud set will work EXCEPT you need 4 studs that are maybe a .5" LONGER ( the ones that come up the middle of the siamesed intake ports)...
I looked at the pictures of the set you had and see what you and Streetwize are saying about the bolts 'tween the intake ports being a little longer. The stock ones aren't long enough, unlike what Mike at Chapman told me.
Brad I was going to use studs , the center studs would work , but the stud did not protrude thru the nut at all , it only went half , maybe 3/4 the way thru the nut , I like them to stick out a few threads so I did some searching and found the longer stud , I sent them along with the heads to CBK , maybe he has the number handy ?
Will the stock ones work , probably , but not for me .
Are those prices for a PAIR ???
Brad , while I was digging thru my junk I found the part number for the longer stud .
It's AR 4.400-1LB 4 are required , they are 4.4 " long I assume by the part number , I was able to order them directly thru summit .
