Page 5 of 9 1 2 3 4 5 6 7 8 9
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2290272
04/18/17 10:01 PM
04/18/17 10:01 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
This picture is looking to the rear of the car and shows the driver's side subframe connector which channels through the torsion bar crossmember and ties into the forward frame rail:
Same rail just viewed from the side:
Passenger side subframe connector tying into the front subframe rail:
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Charger...clean slate in epoxy
1968 Roadrunner w/ 6.1L/6 speed
2010 B5 Challenger SRT 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2294269
04/26/17 01:26 AM
04/26/17 01:26 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The trunk floor pan was really quite solid but there were a couple small holes along the trailing edge that Matt patched:
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2294270
04/26/17 01:26 AM
04/26/17 01:26 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Transmission crossmember from the top..
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2294271
04/26/17 01:27 AM
04/26/17 01:27 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Master cylinder and pedals were sourced from the Challenger SRT8 I parted out.
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2303687
05/13/17 02:18 AM
05/13/17 02:18 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The pedals from the 2009 Challenger are mounted with 6 bolts. We tried to mount it with just 4 bolts, but the pedal bracket flexed too much so a plate with two more mounting points was added:
View from the side. it will still be boxed in
Pedals were hung but the and placed the pedals over the steering column hole. The pedals were heated and straightened. Then they were cut and the foot pads were removed/reoriented
Before:
After
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2303688
05/13/17 02:19 AM
05/13/17 02:19 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
A few more pictures of the modified floor pans under the front bucket seats
View from below:
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2303690
05/13/17 02:20 AM
05/13/17 02:20 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
I ordered a shifter with a 1.0" lateral offset (toward the driver) and 4.25" aft offset. Disregard the 4 speed pattern on the handle!
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2308887
05/22/17 01:36 AM
05/22/17 01:36 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Here's the first part of the tunnel:
The Holley Dominator ECU mounts to the top of the tunnel near the firewall. You can see it in the next 2 pictures:
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2419945
12/17/17 06:29 PM
12/17/17 06:29 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Since the Photobucket extortion attempt, I've been dreading the thread rebuild but I finally bit the bullet and installed all the pictures using imgur.com. If anyone else is still looking for options, you should consider imgur. I've come to like the site in the last week. Anyways...
This is the second section of the tunnel has been roughed in and the new column has been installed. This picture also shown the shifter installed.
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2419946
12/17/17 06:31 PM
12/17/17 06:31 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
On the rotisserie so the IRS K frame can be welded in:
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2419947
12/17/17 06:31 PM
12/17/17 06:31 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Second segment of the tunnel has been welded in. A bezel (seen in bottom right corner) is in process which will have a groove all the way around; carpet will fit into the groove.
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2419948
12/17/17 06:32 PM
12/17/17 06:32 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
After having the Roadrunner dash powdercoated, I changed directions and bought a 1968 Charger Rallye dash frame off one of the facebook trader pages for $100 plus shipping. Here it is in place:
I also picked up a set of Dakota Digital gauges.
[img]http://i.imgur.com/k2hCd8o.jpg?1[/img]
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2419949
12/17/17 06:32 PM
12/17/17 06:32 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
IRS getting welded in
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2419950
12/17/17 06:33 PM
12/17/17 06:33 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Tunnel from below
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2419951
12/17/17 06:33 PM
12/17/17 06:33 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Tunnel and tunnel cover/closeout
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2432186
01/10/18 02:06 PM
01/10/18 02:06 PM
OH
Red383 Offline
Red383  Offline
OH
Very nice fab work, can't wait to see more.
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2455198
02/21/18 06:21 PM
02/21/18 06:21 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Since I eliminated the torsion bars, I have a lot more options for manifolds/headers. Since this car will have about 475-500hp, I decided to go with the factory stainless headers that came on the Jeep Grand Cherokee SRT8. The SRT headers are really durable pieces that also flow very well; they flow as well as any aftermarket shorty header; and SRT headers can easily handle 500hp. Only above that level would longtube headers make a real difference. I couldn't use the factory headers from the Charger/Challenger/etc because they basically point at the firewall in a B body Mopar. The Jeep manifolds point down at a better angle and they hug the block (maybe a little too well) but they will still need some modification on the passenger side in order to clear the bell housing/starter. I also didn't want to spend $750 on a set of mild steel headers that I would have to clearance (ding/dent) anyway.
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2455199
02/21/18 06:30 PM
02/21/18 06:30 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The driver's side manifold bumped into the alterktion motor mount so the easiest thing is to modify the motor mount.
The straight piece was removed in favor of a curved pipe. this if the view looking toward the firewall (rearward)
This view is looking forward
I will have tons of room between the frame rails and manifolds. The manifolds will also be easy to remove if need be. I plan to drive this car a lot...
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2455414
02/22/18 02:02 AM
02/22/18 02:02 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The passenger side crashed hard against the area on the bell housing where the starter mounts. The manifold wasn't even close to seating/mounting.
Matt sliced the passenger manifold, heated it up, and bent the collector end outward a few degrees. Then he welded it back up. Sorry-the pictures aren't very good but the silver area in the next two pictures is where the slice was made.
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2458963
02/28/18 05:06 PM
02/28/18 05:06 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Brake kits are too expensive and since I have parted out SRT8's, I figured I should use what I have. Matt had a bracket machined (and ordered 4 sets for future builds). Now i've got 4 piston Brembo calipers with Dodge rotors (for easy replacement). The other benefit is that my master cylinder and brake pedal are from an SRT Challenger so its a perfect pairing.
