Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed
[Re: 70B5Cuda]
#2290272
04/18/17 09:01 PM
04/18/17 09:01 PM
Posts: 859 Newton, KS
70B5Cuda
Newton, KS
This picture is looking to the rear of the car and shows the driver's side subframe connector which channels through the torsion bar crossmember and ties into the forward frame rail:  Same rail just viewed from the side:  Passenger side subframe connector tying into the front subframe rail:
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger w/ 6.1L/A518/9" 1968 Charger Bomber 440/4spd 1968 Roadrunner w/ 6.1L/6 speed 2010 B5 Challenger SRT 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
[Re: 70B5Cuda]
#2303687
05/13/17 01:18 AM
05/13/17 01:18 AM
70B5Cuda
Newton, KS
The pedals from the 2009 Challenger are mounted with 6 bolts. We tried to mount it with just 4 bolts, but the pedal bracket flexed too much so a plate with two more mounting points was added:  View from the side. it will still be boxed in  Pedals were hung but the and placed the pedals over the steering column hole. The pedals were heated and straightened. Then they were cut and the foot pads were removed/reoriented Before:  After
[Re: 70B5Cuda]
#2303688
05/13/17 01:19 AM
05/13/17 01:19 AM
70B5Cuda
Newton, KS
A few more pictures of the modified floor pans under the front bucket seats   View from below:
[Re: 70B5Cuda]
#2308887
05/22/17 12:36 AM
05/22/17 12:36 AM
70B5Cuda
Newton, KS
[Re: 70B5Cuda]
#2419948
12/17/17 05:32 PM
12/17/17 05:32 PM
70B5Cuda
Newton, KS
After having the Roadrunner dash powdercoated, I changed directions and bought a 1968 Charger Rallye dash frame off one of the facebook trader pages for $100 plus shipping. Here it is in place:  I also picked up a set of Dakota Digital gauges.  [img] http://i.imgur.com/k2hCd8o.jpg?1[/img]
[Re: 70B5Cuda]
#2455199
02/21/18 05:30 PM
02/21/18 05:30 PM
70B5Cuda
Newton, KS
The driver's side manifold bumped into the alterktion motor mount so the easiest thing is to modify the motor mount.  The straight piece was removed in favor of a curved pipe. this if the view looking toward the firewall (rearward)  This view is looking forward  I will have tons of room between the frame rails and manifolds. The manifolds will also be easy to remove if need be. I plan to drive this car a lot...
