Re: Chapman Stage VI 260 questions
[Re: JohnRR]
#241995
03/04/09 07:49 PM
03/04/09 07:49 PM
BradH
... the your current head stud set will work EXCEPT you need 4 studs that are maybe a .5" LONGER ( the ones that come up the middle of the siamesed intake ports)...
I looked at the pictures of the set you had and see what you and Streetwize are saying about the bolts 'tween the intake ports being a little longer. The stock ones aren't long enough, unlike what Mike at Chapman told me.
[Re: Von]
#241996
03/04/09 07:50 PM
03/04/09 07:50 PM
BradH
Guess they went up. That is what they told on Dec. 23.
I like your prices better...
[Re: BradH]
#241998
03/05/09 09:08 AM
03/05/09 09:08 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
Brad I was going to use studs , the center studs would work , but the stud did not protrude thru the nut at all , it only went half , maybe 3/4 the way thru the nut , I like them to stick out a few threads so I did some searching and found the longer stud , I sent them along with the heads to CBK , maybe he has the number handy ?
Will the stock ones work , probably , but not for me .
Are those prices for a PAIR ???
[Re: JohnRR]
#241999
03/05/09 09:21 AM
03/05/09 09:21 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
[quote Are those prices for a PAIR ???
Yep.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: BradH]
#242002
03/05/09 05:54 PM
03/05/09 05:54 PM
JohnRR
U.S.S.A.
FWIW, based on what Chapman is selling them for, plus all the stuff I've figured out will be needed to do the complete swap, this upgrade would cost me right about $4000.
For an old 20-footer street car that's probably only worth $15K, that's a hard # to bite down on w/ a smile.
yikes ...
But Brad you know you don't do this for RESALE value ...
Plus you sold your A12 , this would be a drop in the bucket ...
DO IT , you know you want to ...
[Re: JohnRR]
#242003
03/05/09 06:44 PM
03/05/09 06:44 PM
BradH
... you sold your A12 , this would be a drop in the bucket ...
Well, it would be a noticeable drop of what's left from the A12 sale $$$ after the family finances took a big chunk of it.
Yeah... just don't want to PAY for it.
[Re: BradH]
#242004
03/05/09 10:46 PM
03/05/09 10:46 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
refresh my memory....the 260's are sort of MW size?
what intake would you be planning on using?
that big cfm gain on the heads would get noticably reduced once you bolted a std port M1 onto them. on the other hand, IMO the large cross section MW manifolds like a 440-2 will hamper how well the motor hits the converter with the stall speed you're running.
FWIW, i wouldnt be looking for 600ft/lbs out of that combo on our dyno, but i wouldnt be shocked at 670hp(depending on what the intake manifold choice was).
that EZ295 headed 448 i built a few years ago made over 680hp with the same CR and cam that you have, but only made about 560tq.
[Re: fast68plymouth]
#242005
03/06/09 12:08 AM
03/06/09 12:08 AM
JohnRR
U.S.S.A.
should be stock wedge port window ???
[Re: CokeBottleKid]
#242007
03/06/09 09:31 AM
03/06/09 09:31 AM
BradH
I think the 235s are closer to stock window, 260s are sorta in-between MW and stock.
Are yours still off the engine where you can measure the port size? I was under the assumption that they used a standard port entry... first time I've heard they're "in between" standard and MW. I couldn't really tell from looking at the pictures of your heads that I took in '05 when John had them at Carlisle.
#242008
03/06/09 09:34 AM
03/06/09 09:34 AM
BradH
I have the choice between the ported M1 we dynoed the engine w/ and a Victor 440 with whatever port work I decided to do on it.
And, yes, I was expecting the intake choice would be a compromise between max HP and keeping the torque & throttle response up.
[Re: BradH]
#242009
03/06/09 09:48 AM
03/06/09 09:48 AM
BradH
I tried to settle this by the "scientific method" of flipping a coin: - Heads => buy the heads - Tails => cover my tail financially and save my $ Well, I flipped... and... it... came... up... heads. And, yet, I still don't feel 100% committed about buying them. So, that tells me I'm not ready to drop the cash on 'em. Well, it was a cool idea in theory.
[Re: CokeBottleKid]
#242010
03/06/09 10:05 AM
03/06/09 10:05 AM
JohnRR
U.S.S.A.
Thanks Eric for the correction , since I never got that far I never really checked it against a gasket .
[Re: BradH]
#242011
03/06/09 10:07 AM
03/06/09 10:07 AM
JohnRR
U.S.S.A.
Sell the stage 6's ??? I could also use another set of heads that will never see the light of day once they got in my basement ...
Plus those would actually bolt onto an engine ???
kidding ...
[Re: JohnRR]
#242013
03/06/09 11:22 AM
03/06/09 11:22 AM
BradH
Cool... I'll give you the address where you can send the $1000 deposit for them. We can work out the rest of the details (final price, etc.) later, right?
Oh, you simply need to apply more "precision" work to solve that issue.
[Re: Streetwize]
#242014
03/06/09 11:23 AM
03/06/09 11:23 AM
BradH
I'd be willing to let you try out my 285's on your motor if you want...
That's a generous offer. I doubt I'd be able to take you up on it, but it's appreciated, regardless.
