Re: Starting to work on the Duster
[Re: AndyF]
#2428983
01/04/18 05:20 PM
01/04/18 05:20 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
Well Id look to keep the front wheel as narrow as possible. Weld sells 17" front race wheels as well as other...
[Re: Dave Hall]
#2429165
01/04/18 08:45 PM
01/04/18 08:45 PM
Posts: 31,002 Oregon
AndyF
I was reading over the post and initially you were going to get it running and sell it. Has the goal changed? Let's just say the goal posts have moved. Sponsor money means I need to put a lot more effort into the project.
[Re: AndyF]
#2431403
01/09/18 12:50 AM
01/09/18 12:50 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I was reading over the post and initially you were going to get it running and sell it. Has the goal changed? Let's just say the goal posts have moved. Sponsor money means I need to put a lot more effort into the project. Sponsor money??,, Just where have the Goal Posts moved to. I hope that means not only adding a lot of Sponsored parts, but using all those combined parts and maybe running this Duster down the track. Your engine building Hp producing dyno skills are Stellar. Maybe we will get to see your skills of applying that Hp down the track in the sponsored Duster??? I hope that's where the new Goal Post has moved .
[Re: AndyF]
#2431866
01/09/18 10:20 PM
01/09/18 10:20 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Decided to install a new Strange pinion yoke with an 8 magnet trigger wheel. This will give me driveshaft speed as well as a signal for the speedometer. Maybe even an odometer? Or I might use GPS for the odometer, not sure yet.
One problem I ran into is that this pinion yoke is 1/2 inch longer than the yoke that was on there so now I'll need to shorten my brand new driveshaft. Couldn't you just move the rear back 1/4" and the drivetrain forward 1/4" and not cut that beautiful drive shaft Just put a spacer on the front spring hanger and call it good Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2431929
01/09/18 11:37 PM
01/09/18 11:37 PM
Sport440
Canton, Ohio
[quote=fourgearsavoy][quote=AndyF]Decided to install a new Strange pinion yoke with an 8 magnet trigger wheel. This will give me driveshaft speed as well as a signal for the speedometer. Maybe even an odometer? Or I might use GPS for the odometer, not sure yet.
No need to use a GPS for the odometer. The same trigger wheels signal sent to a Electronic programmable speedometer actuates both MPH and odometer miles. You may even be able to Share the signal from just one pick up to feed your both your Electronic Speedometer and your other driveshaft race pac system.
Autometer sells Electronic programmable speedometers. The one I bought was the ATM 1388, for like 130 bucs. registered MPH and odometer miles with the same signal. Installed it on a 38ft, oil well swab truck, Pretty trick for a rig like that.
Further, programing it wasn't that complicated as you would think. You would think that you would have to consider Rear gear ratio and tire size, to figure all the math out.
Nope, all that was needed was to go measure out a mile with a vehicle and mark it, then get at the start line, with the rig, hit the programming button on the speedo, and drive to the measured mile, re hit the program button, and you done. .
[Re: fourgearsavoy]
#2432054
01/10/18 03:20 AM
01/10/18 03:20 AM
AndyF
One problem I ran into is that this pinion yoke is 1/2 inch longer than the yoke that was on there so now I'll need to shorten my brand new driveshaft. Couldn't you just move the rear back 1/4" and the drivetrain forward 1/4" and not cut that beautiful drive shaft Just put a spacer on the front spring hanger and call it good Gus I couldn't think of a good alternative to cutting the driveshaft so I shipped it back to Strange. They only charge $80 to shorten the driveshaft so I figured that was the cost I had to pay for changing my mind. The engine and rear end location are fairly well locked in at this point. The headers are so big that they dictate where the engine has to be and the rear leaf hangers have been welded into the frame so there is no easy way to move them. The rear tires are very large and the tubs were built around them so I don't think I want to move the rear axle.
[Re: Sport440]
#2432198
01/10/18 02:34 PM
01/10/18 02:34 PM
AndyF
I haven't figured out the programming end of it yet but the plan at the moment is to run this car without any gauges. I'll just use the digital dash from the EFI system and push all of the data thru it. So the digital dash will have driveshaft RRP and a speedo if I can figure it out and an odometer if I can figure it out. I've torn out the dash and will not install anything other than a bracket for the LCD. I think I'll also have a starter button and a ignition switch and maybe a headlight switch. Everything else will be controlled by the EFI.
[Re: AndyF]
#2438368
01/21/18 01:17 PM
01/21/18 01:17 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
That's a pretty good plug for Car Craft. Now i'm going to go out and buy a copy.
[Re: AndyF]
#2440551
01/25/18 02:16 PM
01/25/18 02:16 PM
Posts: 3,837 Central Missouri Fort Leonard...
mopar65
Power knob!
Actually that is the fill port. Just big enough for a funnel or a nozzle on a gas station pump. Looks like a great set up Andy. Did you get the 450L pump and did it come with the Fuel line fittings?
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
