Re: Mopar RB 572 1000 HP Project 1970 Cuda
[Re: Raffaplymouth60]
#2416548
12/11/17 12:13 AM
12/11/17 12:13 AM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
That is a very nice looking engine along with a nice looking garage and other toys in there. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Your engine compartment looks great but if you want a better looking upper radiator hose, look into the Dayco #71654.
#2416689
12/11/17 11:22 AM
12/11/17 11:22 AM
Posts: 195 Italy
Raffaplymouth60
Italy
1970 Cuda 496 street driven 9.22@150 1971 Demon 572 7.82@176 1957 Desoto Adventurer Convertible 345 Hemi 1958 Plymouth Fury Christine 2008 Dodge Ram 1500 Hemi 1970 Dodge ChallengerRT 6pack 4 speed 1 of 135 1968 Dodge Charger RT 4 speed
#2416691
12/11/17 11:32 AM
12/11/17 11:32 AM
Posts: 195 Italy
Raffaplymouth60
Italy
hello Guys ! i have some question on oil pressure ...
oil pressure is :
cold engine idle 1350 rpm 65 psi rev over 3000 85 psi
warm engine idle 1350 rpm 25 psi rev over 3000 55 psi
in my old 496 was at 75-80 psi also at warm engine at wot
Remember ... i have _Milodon billet oil pump with external single line and GRP aluminium rod with rod clearance .0019"
i have restrictor of .040 on heads with TD rockers , the gauge pointer at warm engine at wot make a vibration at 55 psi
oil weight is Valvoline 10w60 Racing
[Re: 70satelliteguy]
#2416712
12/11/17 12:23 PM
12/11/17 12:23 PM
Posts: 195 Italy
Raffaplymouth60
Italy
Raff, what size headers did you end up using and what weight is your Cuda? Do you know what those -1 Indy heads flow? That car is beautiful!! Thanks mike 2 1/4 headers , indy 440-1 flow is 365 cfm , weight is 3800 LB , with 496 old engine best ET was 9.2 ... my goal is 8.8 !!
#2416713
12/11/17 12:29 PM
12/11/17 12:29 PM
Posts: 195 Italy
Raffaplymouth60
Italy
oil pressure is :
#2416735
12/11/17 01:30 PM
12/11/17 01:30 PM
Posts: 3,842 N.E. Ohio
6bblFLASH
N.E. Ohio
oil pressure is :
oil weight is Valvoline 10w60 Racing 55 lbs is enough,however I would think it would be higher too. Relief spring adjustable? How warm is warm temp. wise.? Maybe try another oil filter just out of curiosity ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
#2416760
12/11/17 02:18 PM
12/11/17 02:18 PM
Posts: 195 Italy
Raffaplymouth60
Italy
"with 496 old engine best ET was 9.2 ... my goal is 8.8 !! "
Raff Was the ET with the 496 on motor or with NOS? Mike 9.2@150 mph with 496 indy 295 ported and 350 HP of nitrous with progressive controller , 727 with launch in 2nd 250 hp in 60ft and 350 after 2.5 sec
[Re: 6bblFLASH]
#2416761
12/11/17 02:19 PM
12/11/17 02:19 PM
Posts: 195 Italy
Raffaplymouth60
Italy
oil pressure is :
oil weight is Valvoline 10w60 Racing 55 lbs is enough,however I would think it would be higher too. Relief spring adjustable? How warm is warm temp. wise.? Maybe try another oil filter just out of curiosity yes relief is adjustable with screw , warm temp is 180f, oil filter already changed
