Reverse Pattern Slap Stick #2412605
12/03/17 10:42 AM
12/03/17 10:42 AM
Bradenton, FL
Benforsp Offline OP
Benforsp  Offline OP
Bradenton, FL
At one time I remember reading that someone had ground one of the tabs of a factory e-body shifter to make it work with a reverse pattern shifter. Basically you pulled it back for second without having to push the button and then for third you would push the button. I have removed the console in my car and I can’t figure out which tab to grind off? Can anyone tell me or engine have a picture?
Thanks in advance!
Re: Reverse Pattern Slap Stick [Re: Benforsp] #2412614
12/03/17 11:26 AM
12/03/17 11:26 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Re: Reverse Pattern Slap Stick [Re: Benforsp] #2412956
12/04/17 05:23 AM
12/04/17 05:23 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i did this mod but it wasn't a great success. i pulled the slapstik & fitted a B&M Hammer shifter. it works much better & i even have a chick race my car & she has zero problems now
Re: Reverse Pattern Slap Stick [Re: Benforsp] #2413200
12/04/17 07:14 PM
12/04/17 07:14 PM
Bradenton, FL
Benforsp Offline OP
Benforsp  Offline OP
Bradenton, FL
Dvw,
I have seen those but they were out stock for a long time. I might give it a try. Anyone had any luck with them?
Rebel,
I have a pro-ratchet shifter waiting to go if I can’t make this work. I’m not sure how it will fit though? Seems awfully large to fit in the hole.
Re: Reverse Pattern Slap Stick [Re: Benforsp] #2413226
12/04/17 08:29 PM
12/04/17 08:29 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
The one in my buddy's Charger works flawlessly.
Doug
Re: Reverse Pattern Slap Stick [Re: Benforsp] #2413248
12/04/17 09:20 PM
12/04/17 09:20 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
We have the Cope plate on our reverse manual Challenger with the stock slap stick, it works perfectly. I've raced with it many times.
Re: Reverse Pattern Slap Stick [Re: Benforsp] #2413541
12/05/17 01:10 PM
12/05/17 01:10 PM
Bradenton, FL
Benforsp Offline OP
Benforsp  Offline OP
Bradenton, FL
Well I ordered up a plate today. Thanks for all the advice. Seems people have had good luck so why not give it a try!
Thanks.
Re: Reverse Pattern Slap Stick [Re: rebel] #2414025
12/06/17 02:02 AM
12/06/17 02:02 AM
WI
Brewzer67 Offline
Brewzer67  Offline
WI
When you say you did this mod, are you speaking of using the shift-r-gate from Cope, or did you massage your stock shifter gate? Or, did you use the original shift-r-gate product from Duncan Motorsports? I am asking because I used the one from Duncan and it worked well except for the fact the plate was made of aluminum and it galled very easily. Once it galled it wasn't very good after that until you removed it and polished the burrs. Then it would work again for a while and burr up again. I think if it was made of steel it would have been fine.
