Axle resplining #2412293
12/02/17 05:04 PM
12/02/17 05:04 PM
ohio
bigblockrik Offline OP
ohio
Any body know of some one in the cincinnati area that can do them.
Re: Axle resplining [Re: bigblockrik] #2412364
12/02/17 08:16 PM
12/02/17 08:16 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
Ship them to Moser... three day turn around.
They shortened and resplined a pair of 9 1/4" axles for me. I shipped them Monday they were back Thursday...
Re: Axle resplining [Re: bigblockrik] #2412365
12/02/17 08:17 PM
12/02/17 08:17 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
iagree
Re: Axle resplining [Re: FastmOp] #2413010
12/04/17 12:27 PM
12/04/17 12:27 PM
an8sec70cuda Offline
iagree Moser is good and has really quick turnaround. Sent my axles in last year to be drilled and tapped for 5/8" studs. They drilled/tapped them and shipped them back the same day they received them from me.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Axle resplining [Re: bigblockrik] #2413084
12/04/17 03:02 PM
12/04/17 03:02 PM
I think any time you cut the end of the axle off and have it resplined you should have it heat treated on that part due to possibly having to have the outer axle diameter turned down removing the outer layer of heat treated material scope twocents
Re: Axle resplining [Re: bigblockrik] #2413442
12/05/17 03:16 AM
12/05/17 03:16 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
axel are not surface hardened they are treated all the way through !
if only the surface was hard they would snap easily !
aso they are treated to have some flex to prevent snaping off from being too brittle.
Re: Axle resplining [Re: Cab_Burge] #2413447
12/05/17 03:20 AM
12/05/17 03:20 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
This used to be a big part of Dutchman's business. They used to anneal, machine, and then heat treat. Now they just grind off the outer hardened layer and spline as-is. The new owner moved the business to Idaho leaving no local shop that would do it. I might try doing my own. realcrazy runaway
Re: Axle resplining [Re: calrobb2000] #2413711
12/05/17 06:22 PM
12/05/17 06:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By calrobb2000
hi
Depends on the axle. Stock axles are typically hardened to 1/16”, whereas aftermarket axles are usually hardened to 3/16” or more.
Re: Axle resplining [Re: calrobb2000] #2413737
12/05/17 07:07 PM
12/05/17 07:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
hi
In the late 70s they were heat treated to 57-58
rockwell C... I had some axles make for one of
the projects at Chrysler
wave
