340 Motor Mounts #2411054
11/30/17 12:12 AM
11/30/17 12:12 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I am going to replace my motor mounts this Winter. Are there any better than average that you would suggest? Any to stay away from?
Street E body.
Re: 340 Motor Mounts [Re: YO7_A66] #2411062
11/30/17 12:21 AM
11/30/17 12:21 AM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
I've had a set of stock mounts on my 340 Cuda for 27 years on three different engines and still in great shape.
11B40
Re: 340 Motor Mounts [Re: JonC] #2411065
11/30/17 12:30 AM
11/30/17 12:30 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I plan on pulling them and checking them out first. But I want an idea of what to get in case they are bad.
NAPA shows a generic description on their web sight. I don't want the high dollar Year One items. Anyone bought new mounts lately that fit the 340?
Re: 340 Motor Mounts [Re: YO7_A66] #2411071
11/30/17 12:51 AM
11/30/17 12:51 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
None of the parts store mounts are good. Especially stay away from Anchor or anything else made in India...
Re: 340 Motor Mounts [Re: YO7_A66] #2411073
11/30/17 12:54 AM
11/30/17 12:54 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
For anything I own & drive, solid mount the driver side & stock on the other side.
Re: 340 Motor Mounts [Re: YO7_A66] #2411168
11/30/17 10:04 AM
11/30/17 10:04 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The cheap ones at the auto stores don’t fit well without grinding to fit on the last two cars I did. I’ve used “ Mighty Mounts”. There on the web. They are not cheap.
Re: 340 Motor Mounts [Re: YO7_A66] #2411298
11/30/17 02:52 PM
11/30/17 02:52 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I run solids on both sides, they do raise my engine higher up than i like because of my Shaker..and they do rattle the whole car...but then again, I love it..
Re: 340 Motor Mounts [Re: AARCONV] #2411569
12/01/17 12:01 AM
12/01/17 12:01 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Thanks for the replies.
How rough does it feel with one solid mount?
Re: 340 Motor Mounts [Re: YO7_A66] #2411572
12/01/17 12:07 AM
12/01/17 12:07 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
No noticeable change.
Re: 340 Motor Mounts [Re: YO7_A66] #2411574
12/01/17 12:10 AM
12/01/17 12:10 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Well, as far is vibrations.
A noticeable change can be felt in the throttle response some because the engine will no longer torque over.
Re: 340 Motor Mounts [Re: Alaskan_TA] #2411577
12/01/17 12:13 AM
12/01/17 12:13 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Mine torques over too much in my eyes which has me wanting to pull them and check them out.
Any recommendation on a solid?
Thanks!
Re: 340 Motor Mounts [Re: YO7_A66] #2411581
12/01/17 12:16 AM
12/01/17 12:16 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I use this type;
https://www.summitracing.com/parts/mor-62540/overview/make/dodge
Sold as a pair, so one pair does two cars if only used on the driver side.
Re: 340 Motor Mounts [Re: Alaskan_TA] #2411591
12/01/17 12:36 AM
12/01/17 12:36 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Thank you!
Re: 340 Motor Mounts [Re: YO7_A66] #2411667
12/01/17 04:01 AM
12/01/17 04:01 AM
I use to race NHRA stock, a lot of the Mopar SB A body racers would weld a strap between the upper and lower parts on the intire length of the left mount(drivers side) to make those stock mounts solid, do both sides, front ands rear, not the tops and bottoms scope twocents
Re: 340 Motor Mounts [Re: YO7_A66] #2411692
12/01/17 10:18 AM
12/01/17 10:18 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
What about the Schumacher torque straps with the original style motor mounts?
Re: 340 Motor Mounts [Re: YO7_A66] #2411698
12/01/17 10:35 AM
12/01/17 10:35 AM
Someone said something about filling the gaps in the black material with something, I forgot what, silicone/TRS? for additional support.
Re: 340 Motor Mounts [Re: RapidRobert] #2411745
12/01/17 01:02 PM
12/01/17 01:02 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
That's with a a spool type 73-up A and B body deal.
Re: 340 Motor Mounts [Re: autoxcuda] #2411757
12/01/17 01:33 PM
12/01/17 01:33 PM
^^^ yes you are right
Re: 340 Motor Mounts [Re: RapidRobert] #2412200
12/02/17 12:51 PM
12/02/17 12:51 PM
moparx Online content
moparx  Online Content
the filler material i have used for this [spool type mount] is just common windshield urethane in a caulking gun tube. works great, and it's not picky on manufacturer brand. just clean the holes well. i use lacquer thinner. hope this helps.
beer
Re: 340 Motor Mounts [Re: moparx] #2412218
12/02/17 01:26 PM
12/02/17 01:26 PM
hope this helps.
It sure does & I was wishing I had asked that very question when I posted above as I have spools on the stock car & it reminded me that it would be advantageous if I filled em.
