Re: Rotisserie? [Re: Stanton] #2410826
11/29/17 06:08 PM
11/29/17 06:08 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Originally Posted By Stanton
I see so much China bashing on here I just thought I'd point this out. Guys won't run a $50 China water pump on their motor but they'll put their rare hemi car on a Chinese rotisserie. Personally, I see no issues with the unit, just making the point about it being an "offshore" unit. Don't whine if "making America great again" doesn't happen in your lifetime !
You have issues. I have a backyard full of maple leaves that need to be removed.
It will make my piece of America great again.
Re: Rotisserie? [Re: Stanton] #2410883
11/29/17 07:32 PM
11/29/17 07:32 PM
ONTARIO,CANADA
604 Hemi GTX Offline OP
ONTARIO,CANADA
So let me ask you this?
Are all the components on your rotisserie made in America?
Kevin
Re: Rotisserie? [Re: 604 Hemi GTX] #2410897
11/29/17 07:47 PM
11/29/17 07:47 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
One thing I noticed, tire size, if you're going to roll it out in your gravel-dirt driveway you need large diameter tires (14-16" or bigger). Those little ones will dig into the ground and won't roll. I've been looking at a set of tow dolly wheels to slip on when I take outside to pressure wash.
I also made small screw jacks for each wheel, takes pressure off rubber tire and stabilized the whole unit, no wiggles.
I know mine was made overseas but I keep updating and making it work easier as I use it. Looking for a worm drive so as to crank it around to any position that I need, no need for a pin or to lock down. It's one of the best, most useful things I've ever bought.
Re: Rotisserie? [Re: 604 Hemi GTX] #2411251
11/30/17 01:24 PM
11/30/17 01:24 PM
ONTARIO,CANADA
ONTARIO,CANADA
So I bit the bullet and ordered a rotisserie this morning
https://www.mile-x.com/titan-rot-4500-au...AiABEgJRyfD_BwE
Thanks for all the input guys much appreciated
Kevin
Re: Rotisserie? [Re: 604 Hemi GTX] #2411323
11/30/17 03:57 PM
11/30/17 03:57 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
That looks like a real nice heavy duty unit for the money.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Rotisserie? [Re: 604 Hemi GTX] #2411410
11/30/17 06:52 PM
11/30/17 06:52 PM
ONTARIO,CANADA
ONTARIO,CANADA
Yep now the waiting game then the hotrod gets put on it and the body work starts.
Now I’m getting excited
Kevin
Re: Rotisserie? [Re: 604 Hemi GTX] #2411426
11/30/17 07:32 PM
11/30/17 07:32 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Did you also order the attachment brackets? I failed to... and had to wait an additional 2 weeks... frown
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Rotisserie? [Re: 604 Hemi GTX] #2411525
11/30/17 11:19 PM
11/30/17 11:19 PM
Maryland
MoparMike1974 Offline
Maryland
I got mine from John @ UScartool. I paid $1200 but that was back when they first started selling them. They are much more $$ now.
http://store.uscartool.com/deluxe-rotisserie.html
Re: Rotisserie? [Re: 604 Hemi GTX] #2411684
12/01/17 09:15 AM
12/01/17 09:15 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
I built mine as well.
Here is a rotissorie I built several years ago. I featured it before over on Garage Journal, one of several other forums I frequent.
Features include: (1) arbor locks with spring loaded pins where the pin handle holds the pin in the retracted position for one man operation; (2) hydraulic jacks for raising but hitch pins in double shear to ensure arbors are concentric; (3) bushed center of gravity adjuster to raise or lower body to adjust for balance (use deep well socket and impact gun on coupling nut); (4) caster wheels with brakes at all corners - I used an oil pan drain bolt to lock wheel at 90 degrees; (5) push handles on both ends.
I studied many designs out there before building this. Most suffer from lack of keeping the arbors concentric which basically creates a bent crank and impedes rotation. I wanted to ensure concentric axis of rotation yet be able to tune the offset to get the car's CG on the axis of rotation which then balances the body. The nut and pneumatic impact make it quite easy. The hitch pins keep the axis of rotation in alignment without stress on the jacks
Body On.JPGArbor with rotation lock.jpgBushed CG Adjuster.jpgOverall View.jpg
Re: Rotisserie? [Re: JMCFAN] #2411753
12/01/17 01:23 PM
12/01/17 01:23 PM
ONTARIO,CANADA
ONTARIO,CANADA
I looked at there’s and I’m just going to make them
Kevin
Re: Rotisserie? [Re: 604 Hemi GTX] #2412439
12/02/17 10:17 PM
12/02/17 10:17 PM
Minn
SportF Offline
SportF  Offline
Minn
The unit above looks very well built. How do you rotate it?
Re: Rotisserie? [Re: SportF] #2412443
12/02/17 10:21 PM
12/02/17 10:21 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
By hand once balanced. Grab the t-bar and spins nice.
