Re: A518 floor pan mods - 69 charger ?? [Re: IMGTX] #2409850
11/27/17 10:57 PM
11/27/17 10:57 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Originally Posted By IMGTX
On the mod you did.
Did you trim anything on the transmission or just thin out the Torsion bar crossmember?
Same as above pictures of CNXT
Re: A518 floor pan mods - 69 charger ?? [Re: BDW] #2410069
11/28/17 12:34 PM
11/28/17 12:34 PM
moparx Offline OP
moparx  Offline OP
i was figuring on trimming quite a bit on those ribs. i wonder how much case strength would be lost by trimming all but approximately 1/2" off of those ribs ? i don't have a core transmission yet, but i have a couple of local leads.
beer
Re: A518 floor pan mods - 69 charger ?? [Re: moparx] #2410511
11/29/17 02:03 AM
11/29/17 02:03 AM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
If you are buying the trans as a core then do yourself a favor.
Gut the trans, then do your mock up with just the empty case.
Once everything fits, build the trans and install.
Those things are HEAVY.
Re: A518 floor pan mods - 69 charger ?? [Re: moparx] #2410527
11/29/17 02:33 AM
11/29/17 02:33 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Yeah... or use one of these....
Re: A518 floor pan mods - 69 charger ?? [Re: mgoblue9798] #2410707
11/29/17 02:50 PM
11/29/17 02:50 PM
moparx Offline OP
moparx  Offline OP
haha my old carcass learned that a LONG time ago ! unfortunately franky, my shop only has an eight foot ceiling, and i have had no luck so far conning my best friend into buying a lift......
beer
Re: A518 floor pan mods - 69 charger ?? [Re: moparx] #2410908
11/29/17 08:10 PM
11/29/17 08:10 PM
BDW Offline
BDW  Offline
I picked up a used Kwik Lift for $400 when I did the swap, would have been a pain without it.
Re: A518 floor pan mods - 69 charger ?? [Re: CSK] #2411089
11/30/17 01:38 AM
11/30/17 01:38 AM
IMGTX Offline
IMGTX  Offline
On the mod you did.
Interesting because I did the same trim on my 70 ebody and didn't have to touch the crossmember or body at all. work
Re: A518 floor pan mods - 69 charger ?? [Re: BDW] #2411255
11/30/17 01:29 PM
11/30/17 01:29 PM
moparx Offline OP
moparx  Offline OP
funny you should mention that. several years ago, i drew up and fabbed a lift similar to the "quick lift", but used truck air bags to raise and lower it, putting the tire bottom 20" in the air. i have all the parts made, but life dealt me a tough hand, and it's only about half put together. initial testing proved it will work as designed, but it's just one of many projects i need to finish. the bags are supposed to support 7000lb at 10psi. there are safety stands to support the rear of the ramps in use, while the front tires are supported on "piers" at the front.
beer
Re: A518 floor pan mods - 69 charger ?? [Re: moparx] #2411288
11/30/17 02:32 PM
11/30/17 02:32 PM
GA
roadrunninMark Offline
GA
CSK, is that an aluminum driveshaft? Did you get it out of a RT Dakota or aftermarket?
Re: A518 floor pan mods - 69 charger ?? [Re: roadrunninMark] #2411425
11/30/17 07:32 PM
11/30/17 07:32 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
had it made
