Ramcharger gas tank source? #2408643
11/25/17 01:34 PM
11/25/17 01:34 PM
Port Saint Lucie, FL
ChallengerGary Offline OP
My son's 1989 Ramcharger is leaking fuel. Anybody know where to buy a new gas tank?
Re: Ramcharger gas tank source? [Re: ChallengerGary] #2408646
11/25/17 01:45 PM
11/25/17 01:45 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
They're made of unobtainium. Best option I know of is:
http://www.aerotanks.com/vehicles/dodge.html
If you're going to use the engine mounted fuel pump you'll be fine, otherwise you'll have to come up with an alternative electric fuel pump arrangement.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Ramcharger gas tank source? [Re: ChallengerGary] #2408674
11/25/17 02:51 PM
11/25/17 02:51 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
http://www.nwmp.com/
I got mine at the local 4x4 store.
it came from;
northwest metal products--(which is a subsidiary of s.ca. rv products, inc. - it says on the label)
nw mp forest grove, ill.
503-359-4427
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Ramcharger gas tank source? [Re: ChallengerGary] #2408779
11/25/17 08:03 PM
11/25/17 08:03 PM
Wills Point, Texas
Hugh Jorgan Online work
Hugh Jorgan  Online Work
Wills Point, Texas
Re: Ramcharger gas tank source? [Re: Hugh Jorgan] #2408992
11/26/17 03:04 AM
11/26/17 03:04 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
have you considered using fuel tank liner,it comes by the quart and is simple to use and it works on metal tanks,i haven't tried it on plastic,but the manufacture should be able to tell you
the brand i used is called red kote,or redcote?
my ladder of success is missing some rungs
Re: Ramcharger gas tank source? [Re: Hugh Jorgan] #2409080
11/26/17 01:10 PM
11/26/17 01:10 PM
Originally Posted By Hugh Jorgan
I would be fine with a good used one.
Re: Ramcharger gas tank source? [Re: amxautox] #2409081
11/26/17 01:11 PM
11/26/17 01:11 PM
it came from;
503-359-4427
Looks like they don't make tanks anymore. They sold that part of their business and the new company does not list the RC as one they make. I will email them and see - thanks
Re: Ramcharger gas tank source? [Re: ChallengerGary] #2412581
12/03/17 04:54 AM
12/03/17 04:54 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
Not sure what size came on the Ram Chargers but I have a plastic one that came off my '80 D150. I think its an 18 gallon.
Re: Ramcharger gas tank source? [Re: ChallengerGary] #2413520
12/05/17 12:25 PM
12/05/17 12:25 PM
the d150 tank is totally different than the '89 Ramcharger. The RC tank sits in the very rear of the truck between the frame rails. The D150 tank sits on the side of the bed on the outside of the frame rail.
BTW - solved the problem. Turns out it was a small crack. Was able to "plastic weld" it and now she's as good as new. While I was at it, I replaced the in-tank fuel pump and strainer. Glad I did that smile
Re: Ramcharger gas tank source? [Re: ChallengerGary] #2414546
12/07/17 02:17 AM
12/07/17 02:17 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
ChallengerGary,
My truck came with 2 tanks, one on the side and one in the back between the frame rails.
Re: Ramcharger gas tank source? [Re: ChallengerGary] #2415024
12/08/17 12:35 AM
12/08/17 12:35 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The rear tank on the pickups is a lot smaller the most RC tanks. Pickup rear tanks are usually 18 gal range and the RC tanks are in the 35 gal range, at least the ones around here were. I suspect the pickup tank would fit in the RC if you had the straps and sending unit. The RC tank is a lot deeper. Gene
