Tar in trunk on my 37, Amazing preservation #2408094
11/24/17 12:46 AM
11/24/17 12:46 AM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
So I picked up this 1937 Plymouth 2 door business coupe and I'm amazed by how rust free it is. I cleaned the trunk out today and it was covered in a asphalt tar like product. It was lifting off in areas so I decided to remove some of it and I was amazed how preserved the metal was. zero rust, no pitting and the primer looks almost new. Was this tar stock? Has anybody ever seen anything like this before?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Tar in trunk on my 37, Amazing preservation [Re: AZ_A12_BEE] #2408099
11/24/17 12:48 AM
11/24/17 12:48 AM
Dreaming of the 808
Dreaming of the 808
After
Re: Tar in trunk on my 37, Amazing preservation [Re: AZ_A12_BEE] #2408126
11/24/17 02:13 AM
11/24/17 02:13 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Looks great. Take a propane torch & heat the stuff a little & it'll come off like butter. (bench test some of it first & make sure it doesn't splode or burst into flames though on the car!!!)
Re: Tar in trunk on my 37, Amazing preservation [Re: AZ_A12_BEE] #2408140
11/24/17 03:23 AM
11/24/17 03:23 AM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Cool looking ride.
Have a great day
Iowan
"obsolete is neat"
Re: Tar in trunk on my 37, Amazing preservation [Re: AZ_A12_BEE] #2408144
11/24/17 03:39 AM
11/24/17 03:39 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
My 48 & 49 Plymouths had similar tar under coating. My 31 didn't.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Tar in trunk on my 37, Amazing preservation [Re: Hemi_Joel] #2408165
11/24/17 10:44 AM
11/24/17 10:44 AM
moparx Offline
moparx  Offline
my 38 had that exact same stuff not only in the trunk, but also behind the front seat and up the riser to where the trunk floor came through into the passenger compartment. that area was also covered. since it was a business coupe, i'm guessing it was used because it was way more "wearable" than the rubber floor mats of the day, and items could be slid in and out without harming the surface, yet keep said items from sliding back and forth while going down the road.
beer
Re: Tar in trunk on my 37, Amazing preservation [Re: moparx] #2408171
11/24/17 11:07 AM
11/24/17 11:07 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Probably asbestos... work panic
JB Rhinehart, Realist
A-Body's RULE!
Re: Tar in trunk on my 37, Amazing preservation [Re: AZ_A12_BEE] #2408184
11/24/17 11:51 AM
11/24/17 11:51 AM
IN
polaraholic Offline
polaraholic  Offline
IN
Keeps the moonshine from leaking out. drinking
Re: Tar in trunk on my 37, Amazing preservation [Re: AZ_A12_BEE] #2408208
11/24/17 12:57 PM
11/24/17 12:57 PM
o
ChryCoGuy Offline
ChryCoGuy  Offline
o
Pretty cool. Thanks for posting it.
So, does that look like it was applied by the factory, or would it have been something an owner did after the fact?
I suppose it might be difficult to know with a car that has 80 years of history behind it!
Re: Tar in trunk on my 37, Amazing preservation [Re: Rhinodart] #2408227
11/24/17 01:42 PM
11/24/17 01:42 PM
Dreaming of the 808
Dreaming of the 808
Everything had asbestos back then smile
Re: Tar in trunk on my 37, Amazing preservation [Re: ChryCoGuy] #2408229
11/24/17 01:43 PM
11/24/17 01:43 PM
Dreaming of the 808
Dreaming of the 808
I'm just guessing but I think it was factory applied, the primer underneath is too nice to have been applied later
Re: Tar in trunk on my 37, Amazing preservation [Re: AZ_A12_BEE] #2408238
11/24/17 02:12 PM
11/24/17 02:12 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
It could also have been a dealer-installed aftersale item. Probably helped with reducing noise in the trunk.
Re: Tar in trunk on my 37, Amazing preservation [Re: Powerflow] #2408245
11/24/17 02:20 PM
11/24/17 02:20 PM
o
ChryCoGuy Offline
ChryCoGuy  Offline
o
Interesting. Can't recall seeing that before but then most 30s-40s cars I've seen had a rubber mat in the trunk that I wouldn't have looked under.
Re: Tar in trunk on my 37, Amazing preservation [Re: Powerflow] #2408254
11/24/17 02:38 PM
11/24/17 02:38 PM
Dreaming of the 808
Dreaming of the 808
It was very thick in some places, almost 1/4 inch thick
Re: Tar in trunk on my 37, Amazing preservation [Re: AZ_A12_BEE] #2408482
11/25/17 12:29 AM
11/25/17 12:29 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
I don't ever remember seeing much of any original floor pans remaining, on any of the 30s or 40s Mopars I've had, much less what might have been covering them.
There were a few places where I've encountered some type of undercoating that looked a lot like that stuff. I suspected it was originally factory installed. It was some good stuff! I've seen clean shinny steel under it, next to rotted away sheet metal that was not protected by the undercoating. If only the entire floor would have been covered, the sheet metal might have still been good. Gene
Re: Tar in trunk on my 37, Amazing preservation [Re: Sunroofcuda] #2423641
12/25/17 04:14 PM
12/25/17 04:14 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I'd be worried it would catch fire and not being able to put it out.
I have mechanical Aptitude.
I can screw up anything.
Re: Tar in trunk on my 37, Amazing preservation [Re: AZ_A12_BEE] #2423788
12/26/17 12:14 AM
12/26/17 12:14 AM
British Columbia, Canada
Old Ray Offline
Old Ray  Offline
You have probably finished the tar removal but this MIGHT (? confused ) help someone else maybe, well maybe not , well not at all. The heck with it I'm not posting (just kidding).
My '56 Canadian Dodge 2 door wagon (Plodge) has a similar tar on the floor boards under the seats (lower right in pix) and I had a air powered gasket scarper air chisel that I have not used much that worked very well.
