Re: 470 dyno test article
[Re: viperblue72]
#2409598
11/27/17 02:11 PM
11/27/17 02:11 PM
Posts: 31,016 Oregon
AndyF
Andy, Were any other Camshafts tested during any of the trick flow head tests? I am getting the 270 heads and they are going on a 12:1 511. So I am curious if another 5-10 degrees would be worth it. I have not done any cam testing with the 270 heads. The cam I used for the 270 heads is the one that was best with the 240 heads. I'm pretty sure I can find some more power if I start testing cams. Now that I have the 270 heads and the ported intake I'm sure the engine would respond to a little more area under the curve. I'm kind of busy building the Duster at the moment but if I get a little free time I'll research some cams for this engine and then see if I can get it back on the dyno.
[Re: 383man]
#2409599
11/27/17 02:13 PM
11/27/17 02:13 PM
AndyF
Wow Andy you do know how to get awesome power from your Mopars !! Ron Thanks Ron. Not sure I really know in advance how to make power but if you try enough things eventually some stuff works. I chased my tail with rocker arm ratios and cam grinds and crappy intake manifolds and spacers that didn't work and all of that stuff. First pull with the 470 was 620 hp so we've found 150 hp over the past 18 months.
[Re: viperblue72]
#2409611
11/27/17 02:43 PM
11/27/17 02:43 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Andy, Were any other Camshafts tested during any of the trick flow head tests? I am getting the 270 heads and they are going on a 12:1 511. So I am curious if another 5-10 degrees would be worth it. I'm sure that motor combo could benefit from more duration, provided the car has the right pieces to make use of it. Ron trick flow site advertises these numbers ootb intake .100- 72 .200- 154 .300- 230 .400- 288 .500- 322 .600- 343 .700- 352
exhaust .100-58 .200-130 .300-186 .400-222 .500-243 .600-253 .700-262 Exhaust numbers are with a flow tube attached.
[Re: AndyF]
#2409690
11/27/17 05:21 PM
11/27/17 05:21 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Wow Andy you do know how to get awesome power from your Mopars !! Ron Thanks Ron. Not sure I really know in advance how to make power but if you try enough things eventually some stuff works. I chased my tail with rocker arm ratios and cam grinds and crappy intake manifolds and spacers that didn't work and all of that stuff. First pull with the 470 was 620 hp so we've found 150 hp over the past 18 months. Nice work, thats what should happen when one keeps testing and testing and re-testing stuff. I think a lot of guys on here would be supprised how much they could gain from trying some different manifolds, carbs, spacers, rocer geometry, rocker ratio... vs the typical just throw more cylinder head, cam, and compression at it.
[Re: dogdays]
#2409774
11/27/17 08:40 PM
11/27/17 08:40 PM
Posts: 43,141 Bend,OR USA
Cab_Burge
When I first heard of the oil starvation problems with motors running vacuum pumps I thought it was due to tight of clearances on the wrist pins to rod and pistons due to most pin oiling being splash oiling. The oil pump is a suction pump also but it forces liquid through a restrictor, the engine oiling system and has a high pressure bypass system built into the pump so the motor will have a maximum oil pressure at the higher RPM. The oil pump has to battle the negative pressures above the oil level to suck oil into it, or does it Using a vacuum pump does allow thinner rings to seal better which allows the motor to make more power with less oil contamination in the combustion chambers As well as stop some of those pesky tiny oil leaks
[Re: Cab_Burge]
#2409810
11/27/17 09:34 PM
11/27/17 09:34 PM
Posts: 2,461 Sydney,Australia
tex013
Sydney,Australia
Years ago I had a customer bring me his 1968 383 C.I. Charger that he had put a set of after market cast aluminum valve covers on with the stock type PVC and twist on oil filler cap with no vent. It would start and idle fine for a short while(1 1/2 to 2 1/2 minutes) and then slow down by several hundred RPM, the motor was sealed up tight enough that the PCV was making a vacuum in the motor after it suck the pressure out of the motor I put a breather cap on it and he was happy after that A vacuum pump will do the same thing on a leak free motor The pumping action of the pistons and rods going up and down and ring blow by will cause crankcase pressure, especially at high RPM That's funny Cab , 20 or so years ago I had similar issues on a customers stock 308ci Holden , after 20 minutes the motor would stall . Took a little while to work that one out , vented oil filler cap solved it . Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: viperblue72]
#2410050
11/28/17 11:52 AM
11/28/17 11:52 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
exhaust .100-58 .200-130 .300-186 .400-222 .500-243 .600-253 .700-262 Wow thats some nice #'s. I believe they do come CNC ported right out of the box ? Thanks Viperblue72. Ron
[Re: AndyF]
#2410052
11/28/17 11:54 AM
11/28/17 11:54 AM
383man
Balt. Md
Wow Andy you do know how to get awesome power from your Mopars !! Ron Thanks Ron. Not sure I really know in advance how to make power but if you try enough things eventually some stuff works. I chased my tail with rocker arm ratios and cam grinds and crappy intake manifolds and spacers that didn't work and all of that stuff. First pull with the 470 was 620 hp so we've found 150 hp over the past 18 months. And us Mopar people do thank you as you do alot of work in testing parts and letting us know what works in many combo's and myself I thank you. I really enjoy reading about your dyno' runs. Ron
[Re: A990]
#2410131
11/28/17 02:28 PM
11/28/17 02:28 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I modified a PCV so it would flow slightly under vacuum and then put it on the vent side. I now have 2ish inches of crankcase vacuum and it has made a world of difference in throttle response and power/mpg.
I think the PCV has been on the wrong end of the crankcase vent sequence. Can you explain this "wrong side" theory please...........
[Re: A990]
#2411136
11/30/17 03:46 AM
11/30/17 03:46 AM
Cab_Burge
A PCV is a one way valve right? The spring shoves it closed with no vacuum and opens with around 2 + inches of vacuum, correct? If you apply vacuum to the ball side of the valve doesn't that suck it closed?
