470 dyno test article
#2407579
11/22/17 09:59 PM
11/22/17 09:59 PM
Posts: 31,068 Oregon
AndyF
Here is the article from my last round of testing: http://www.hotrod.com/articles/dyno-tested-vacuum-pump-help-engine-make-power/Peak power with the vacuum pump and the Wilson ported intake was 775 hp. That is running unleaded premium with out of box Trick Flow 270 heads. I'm sure that more compression would make more power but we're getting close to the limits of a stock block so no reason to turn up the wick anymore.
Re: 470 dyno test article
[Re: AndyF]
#2407594
11/22/17 10:45 PM
11/22/17 10:45 PM
Posts: 326 Alberta
Wookie316
Alberta
Great article. I want that Manifold. I’ll trade you my untouched one LOL.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: birdtracker]
#2407851
11/23/17 02:10 PM
11/23/17 02:10 PM
AndyF
Andy: could you supply a part number for this cam? "Comp Cams 264/268 solid roller with HXL and HXX lobes" Thanks Birdtracker It is a custom cam. If you want to duplicate it just ask for 264/268 with HXL and HXX lobes. You'll also need to pick a lobe center.
[Re: AndyF]
#2407881
11/23/17 03:09 PM
11/23/17 03:09 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Here is the article from my last round of testing: http://www.hotrod.com/articles/dyno-tested-vacuum-pump-help-engine-make-power/Peak power with the vacuum pump and the Wilson ported intake was 775 hp. That is running unleaded premium with out of box Trick Flow 270 heads. I'm sure that more compression would make more power but we're getting close to the limits of a stock block so no reason to turn up the wick anymore. Andy how much vacuum did the dry sump pump pull? Don
[Re: birdtracker]
#2407883
11/23/17 03:13 PM
11/23/17 03:13 PM
Posts: 9,888 Weddington, N.C.
Streetwize
Weddington, N.C.
True....but how much did the manifold porting cost? or the Dry sump Vaccuum system...or the roller and lifters, or the Pan? I was just stating power to power, but if someone wants to open the discussion up to "Cherry Picking" the costs. Which dyno ready motor cost more for the 775 HP? There was nothing wrong with the Chapman heads...other than the Overpriced MP Marketing. Finally Mopar produced n awesome head out of the box...but they blew it with the exorbinate pricing. The only other "custom" cost vs any other offset intake rocker head (as far as I know) is the $150 billet rocker stands which are arguably well-worth the expense. I think I paid $2400 for my set new but second hand. I mean I get it, there are "promotional considerations" with every new product testing and we're all happy to have solid tech articles to read, but this is Moparts where we should talk "Apples to Apples"....fairly and objectively.
[Re: birdtracker]
#2407909
11/23/17 04:16 PM
11/23/17 04:16 PM
AndyF
do you know what the lobe center was on the one dynoed? thanks Birdtracker Ground 108, installed 104
[Re: cudadon]
#2407910
11/23/17 04:17 PM
11/23/17 04:17 PM
AndyF
Here is the article from my last round of testing: http://www.hotrod.com/articles/dyno-tested-vacuum-pump-help-engine-make-power/Peak power with the vacuum pump and the Wilson ported intake was 775 hp. That is running unleaded premium with out of box Trick Flow 270 heads. I'm sure that more compression would make more power but we're getting close to the limits of a stock block so no reason to turn up the wick anymore. Andy how much vacuum did the dry sump pump pull? Don Not a lot, somewhere around 10 to 12 inches. Neither the dry sump or the vacuum pump were set up to pull a ton of vacuum.
[Re: AndyF]
#2407932
11/23/17 05:14 PM
11/23/17 05:14 PM
Streetwize
Weddington, N.C.
The Cam in my 517 is also 264/268 on 108, but it's a Bullet Hydraulic Roller, makes mad torque and pulls to 6800+ It's been in the motor 10 years now, trouble free.
Thinking of Switching to a Solid roller just so I can run the BAM lightweight pressure fed lifters, save on some of that valvetrain mass.
[Re: AndyF]
#2408248
11/24/17 02:23 PM
11/24/17 02:23 PM
BradH
Andy: could you supply a part number for this cam? "Comp Cams 264/268 solid roller with HXL and HXX lobes" Thanks Birdtracker It is a custom cam. If you want to duplicate it just ask for 264/268 with HXL and HXX lobes. You'll also need to pick a lobe center. My suggestion to birdtracker is to contact Dwayne Porter (fast68plymouth) for the cam, especially since he may have a different recommendation for lobes, depending upon the application.
[Re: AndyF]
#2408472
11/25/17 12:22 AM
11/25/17 12:22 AM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
A 2226B/4134B should be 260/266@ .050
There's usually a few thousand extra $$$$$ to get from 800hp to 900hp.
Of course, "low deck Indy block" doesn't really narrow things down too much. It could be a 451....... Or a 557.
[Re: Alchemi]
#2408633
11/25/17 01:14 PM
11/25/17 01:14 PM
Posts: 1,051 The Great White North
RAMM
Just an Idea....
So in a post a year or so ago it was mentioned that someone in the Engine Masters comp had used a windowed block to reduce effects of pumping losses by increasing the cubic volume of the sump area (no vac pumps in engine masters?)
So if using a vac pump, its got to pull vs a set volume, if you could reduce that volume, it would work better?
So if you put a big sealed triangular wedge under the valley cover you could take out a bunch of CI from the internal space of the motor and make the pump work better? That was my build in 2014 and you are correct-No vac pumps in EMC. I agree with your theory about reducing volume the vac pump has to act on. I also know how theories often pan out. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: AndyF]
#2409185
11/26/17 05:15 PM
11/26/17 05:15 PM
birdtracker
2226 is a HXL lobe that is just a few degrees smaller than the lobe I used. Your 4134 exhaust lobe is a different family. That is an RT lobe with 266 duration.
If you replaced your cam with my cam I doubt you would see much difference. Maybe pick up a little power but I don't think it would be worth the hassle.
800 hp with the Trick Flow 270 heads will take some work. With E85 you can run more compression so you'll want to run as much as possible. If it is a race only deal you'll probably want to throw more cam at it than I'm using. Especially if you have more compression. Don't forget to get the intake ported, that is the key to unlocking some power. Andy: a few people have shown interest with this topic in reguards to the article. Am I wrong that the 270 heads with your cam and ported intake made 775 hp or did you use a different head? What compression height and ratio were you using with the J.E pistons? Are these a shelf piston? The pump gas is what really interests me cause alot of us still drive ours. Thanks Birdtracker
